What prop is best? |
Posted: July-09-2012 at 12:51pm |
Scott, unfortunately, there isnt much demand for your old props. The damaged 12x15 would cost more to repair (~$125) than its worth (~$80-125 in good shape). The 12x16 is a bit of an oddball size, at least for a Correct Craft- the 12" diameter is meant for a smaller 16' boat and those generally came with smaller engines that mated well to props with 13-14" of pitch. You can try listing it to see if theres interest, but it too, would only be worth $80-125 in nice shape.
A new OJ 12x13 would set you back around $300. The Acme would run a little closer to $350 using the CCFan discount from Delta Propeller. |
srbranum
Senior Member Joined: March-06-2010 Location: Huntsville, Al Status: Offline Points: 376 |
Thanks TR,
Sounds perfectly correct to me and I will look in to it and would have one on order today except I don't have the $400(I guess) for a new one. I guess I never imagined there was so much performance and technical issues behind the correct prop. I figure "any prop that does not hit the bottom of the boat is good to go"......Wrong!! Heard from others you are the man when it comes to these things so let me find some money and I will see. If you know anyone who would buy my two props, let me know and that would make things much easier to consider. Scott |
I have to keep her running 'cause I can't afford a new one
Larry, prepare to be impressed. Both are good props, but the Acme is better until you get to the 250+ hp range where youre spinning closer to 5k RPM. The 1210 is definitely the better skiing prop (holeshot, speed holding, mid range punch, etc). Ive seen it outrun the OJ up top most of the time as well... again, on a stock powerplant. Ive seen it push a Ford powered Mustang to the 50mph mark- so it works well on a faster running hull/engine combo as well as the slow ones (like mine).
Scott, personally I wouldnt spend another dime trying to turn an old, inappropriate prop into something that resembles the right one for your boat. The more a prop is repaired, repitched and tweaked, the more flexy it becomes. Keep one around for a spare and get yourself a new wheel that performs properly. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Funny you should say that, Tim. Happens to be one of the other two I have to try. We will see how it goes. I don't have a prop puller and not looking to buy one since it is not something I futz around with on a regular basis, so I am trying to track one down to borrow. I'll really be impressed if the acme out performs the OJ. (maybe its that whole "stock power plant' vs a Chevy thing. |
srbranum
Probably right. Maybe I could sell the 12X16 and have the 12X15 changed to a 12X14 and that would get me a little closer. Is that even possible? My friend John said you can chage a prop like this up or down 1 inch but no more. What do you think? |
I like the acme 1210 better than the Oj 12x13 on a stock powerplant on a 16' boat. Better holeshot and very comparable top end.
That 12x16 is way wrong for that boat... Too bad you didn't inquire prior to getting it fixed. |
I have an idea and it's free. How about going back to the prop shop and ask them what happened??? +1 on the OJ,not as much bling as an Acme CNC but the best prop for the smaller boats.
srbranum
Thanks for the info but after spending $500 on the stump hitting repair and going for a two week vacation starting next friday, the fix I was looking for starts wth the letter F as in "FREE". I'm just thinking it was fine for years and now it's not and I know the boat has no changed and I got my prop fixed. I'm guessing the 12X16 was a 12X15 and the prop shop put it back to spec or 12X16 and now it does not sound right. I could also get my 12X15 repaired for $125 but that does not involve the letter "F"....
Let me also say that before I sound like I know ANYTHING about props (which I don't), I need to take Gun Driver's advice and read the Delta Prop info on the sight. But right now, I need to jump in the truck and head to Nashville to pick up my 5Th boat(Correct Craft, Jetski, 16' Jon boat, Layout boat and .........) a new 10' flatbottom jon boat for my son. See ya'll tonight. Scott |
75 Tique
My 76 tique is the same boat as yours and my 76 OMC/Chevy 305 is pretty much the same motor as yours (the 305 is 230 HP). The stock prop for these boats was a Federal 12 x 14. Not sure how yours came to have such a high pitch prop on it, but I am guessing it was not performing optimally. After 8 years of no problems at all, my federal found its way to the bottom of the lake last week. I was loaned an OJ 12 x 13 to try and am VERY impressed with the performance of that prop, so that would be my recommendation if you are looking to buy new. I havent pulled the trigger yet, as I have a couple others to try, but it's hard to believe either of those will out perform this. (at this point I am referring to hole shot and smoothness and "solidness" of the pull when skiing. I havent been able to check top end yet.)
I am curious as to the top end of your boat with that 12 x 16. In theory it would be faster, but at the same time, I would guess it is limiting the top RPM and hence limiting the top speed. My stock set up ran 50.7, last time GPS'd. I am hoping to find out what I get with the OJ, but I have to track down a GPS, as I don't have one. Top speed isnt critical to me so if I have lost a few mph, I would still go with the 12 x 13. |
srbranum
I recently posted a strut/drive shaft/prop repair to my boat. As in the diaries, its the 1975 skier with the 307 Omc equipped Chevy engine. I damaged the prop that I was running on it which is a 1967 12X16 Ni Bral. When I took it to the shop to be straightened, the technicial said "boy, that thing was way out so I fixed it the way it is supposed to be. I think you will notice a big difference". I think he meant it was not cupped or pitched correct and not that it was damaged from me hitting the stump. In fact, it did not look damaged at all to the naked eye.
Well now it is cavitating in my opinion. Any hard turn or jumping from wave to wave causes the boat to make that sound. No sound as far as I know driving on smooth water, just under the hard turns or jumping a wave. The other prop I have is a 1974 of the same brand but a 12X15. However, it is damaged so I can't try it out. I have run the 1967 year 12X16 for years and never heard this noise until I got it fixed a couple of weeks ago. Can anyone help with advice? Gun Driver suggested I post this. Thanksk, Scott |
