  New Posts New Posts RSS Feed - windshield bolts for ’76 SN
Bill336 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill336 Quote  Post ReplyReply Direct Link To This Post Topic: windshield bolts for ’76 SN
    Posted: November-10-2005 at 8:32am
Why not just use machine bolts and have someone topside hold the bolt in place with a screwdriver while you put the washer and nut on from the bottom? Or see if someone here would buy the T-bolts and ship them to Australia?   It just seems like we may be trying to over-engineer this when an easy solution is available...
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 8:17am
Hey mark, Not sure what roofing bolts are but it made me think of what we call a carriage bolt. Carriage bolts have a domed head with no slot or hex but have a square shank that is typically 1/4 inch down from the head. If you have a way to square off the holes in the windshield frame you could drop the carriage bolt through the hole and it will not turn as you tighten from below. You may still need to grind off the sides of the head so it will fit in the slotted frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 5:58am
If you have a welder make your own. A piece of threaded rod and weld a piece of barstock in the size you need on one end. Have never done it but I'm just trying to throw some ideas out to you.
markb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 7:40pm
I think the only prob with this is that the T bolts have a much longer fitting on the T side of things.
I have placed roofing bolts in the slots without a worry but whether of not they can be tightened is the issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 5:15pm
Maybe get a standard stainless hex head bolt and grind the head down to look and fit like the original t bolts. Might take little time if you need a lot of them but not hard to do . Hold them with a pair of vise grips while grinding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 4:30pm
Looks like I'll be trying an alternative as you just can't buy them in Australia :-(
I might have to see how I will go with normal bolts and nuts. Anyone think of a good subst*tute?
woodyelc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodyelc Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 9:21am
REMOVE THE PLASTIC TRIM ON THE BOTTOM OF WINDSHIELD WHICH IS COVERING THE SCREWS. START IN MIDDLE AND PULL OUT THE TRIM.
woodyelc
Morto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2005 at 6:41am
Hi, on this topic, can anyone tell me how to get the windscreen off our '82 Tique. We're nearly at the stage of painting the deck and it looks like it'll be a lot easier with that out of the way......
Thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2005 at 12:11am
Thanks guys.
I'll see if I can find them locally now I have a name for them.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2005 at 6:31pm
Those bolts are available from Taylormade. Here's a link:
"T" Bolt Hold-Downs Stock No. #9563 (6 per pack)
current boat
94 Sport Nautique
previous boat
78 Martinique
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2005 at 4:41pm
Ive never had my windshield off, but from taling a shot in the dark it souds like you are describing what is called a "elevator bolt" which can be obtained in stainless. Looks almost like a toilet flange bolt??
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2005 at 3:48pm
Hi,
I have been attempting to reinstall my '76 windshield but as can be expected when dissaembled the 30 year old screws were in bad shape.
Replacement of all will be necessary but I am wondering if this is going to be at all possible as I have no idea what I am asking for?
Is there a common name for the type of fittings..they are a bolt with a flat end about 2.5inchs long.
