  New Posts New Posts RSS Feed - Ignition switch
Ignition switch
parrott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parrott Quote  Post ReplyReply Direct Link To This Post Topic: Ignition switch
    Posted: July-16-2012 at 2:18pm
Yeah, I have a call in to skidim now. Looks like the 20 amp but I will let them tell me. Thanks.
1999 Air Nautique
1992 Nautique
1978 Nautique
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 1:13pm
I may have mis-stated on the 50amp(The 50 is the big breaker on the rear of the motor). But the ignition button is at least a 20 amp.
Yes, good idea to double check. There should be some indication on the one you pull out as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote parrott Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 12:12pm
Thanks for the info. I did not know the amps I needed. I am sure Skidim will confirm for me.
1999 Air Nautique
1992 Nautique
1978 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 2:09am
You can get those breakers at Skidim or Nautique parts. N3Boatworks doesn't seem to list the right amperage.
They all look the same, but you need to get the right amperage. I believe that ignition breaker is a 50 amp. The accessories use a lesser amperage, but that one needs the 50 since everything runs through it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote parrott Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 12:33am
Just bought a 1999 Air Nautique with only 320 hrs. Need to sell the 92 SN now! Anyway, the ignition breaker on the dash is pushed in and will not come out. Is there anyway to repair this or just order a new one? Currently just turning the Perko switch off when not in water.
1999 Air Nautique
1992 Nautique
1978 Nautique
