  New Posts New Posts RSS Feed - Looking for rear bench skin
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Topic: Looking for rear bench skin
    Posted: July-18-2012 at 3:15pm
Congratulations!   glad to hear you found what you were looking for.   your prop issues could very well be alignment, Pete did a video on the whole process on youtube. One thing I found was missing from the instruction was that the prop shaft and transmission output shaft may need a light rap with a deadblow to separate if they haven't been separated in a while.    I removed the bolts, and the two were stuck together. it left me wondering if I had missed something, so after careful inspection, and a little persuasion, they came apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 11:20pm
Better quit teasing us and get some pictures up. Congratulations
And change your location
jo-e90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jo-e90 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 11:09pm
It is Not right.
I meant to put 4100 RPM
1997 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 10:56pm
Originally posted by jo-e90 jo-e90 wrote:
61 MPH
Any help on the shaft would be appreciated.
thanks
BS on your speed. Get the GPS out and learn the real truth.
shaft alignment 101
Post Options Post Options   Thanks (0) Thanks(0)   Quote jo-e90 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 10:46pm
61 MPH
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 10:40pm
prop that will not turn by hand, so I ordered gore-tex packing for both.
The Goxtex will not solve the problem. If you are out running it with a prop that won't turn by hand, expect to blow the trans soon.
Did water test and it ran up to 61,
61 what???
Post Options Post Options   Thanks (0) Thanks(0)   Quote jo-e90 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 10:14pm
yes, I did buy that 1992 aqua colored ski with tower and 5.8 Pro Boss. 1200 hrs.
I have just been so busy reading the whole manual over and over figuring out how to fix the sticky steering and prop that will not turn by hand, so I ordered gore-tex packing for both and spark plugs, etc.
Did water test and it ran up to 61, cold start. fuel guage does not work and no radio or speakers. Owner was the first and very honest with me. It was a camp boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 10:08pm
tuck a towel in around it, and run till winter [:)}   you can worry about upholstery when it's not good skiing weather.    I'd love to know the answer to Gary's question too, as I noticed your leak and tower post...   inquiring minds....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 9:22pm
Did you buy something or are you putting a boat together part by part You could check a site sponsor here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jo-e90 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 8:25pm
92 CB
