  New Posts New Posts RSS Feed - Advice on Removing Registration Numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Advice on Removing Registration Numbers
    Posted: July-22-2012 at 9:43am
Originally posted by Airgrabber Airgrabber wrote:
Pete, what's the real story on CQ,s boat
The source of the fire was never confirmed but it is believed to have started on the outside of the garage, burnt though the wall and got the boat.
Airgrabber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Airgrabber Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2012 at 9:31am
Life is good. Work hard! Play Hard!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2012 at 9:27am
Best post ever, laughing my a$$ off.
Marc,
You may not know this but that picture Larry posted IS CQ's boat!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Airgrabber Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2012 at 9:06am
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 6:56pm
Originally posted by KRoundy KRoundy wrote:
Plus 2 on 3M Eraser Wheel
+ 3. It's like magic.
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 6:54pm
Originally posted by 75 Tique 75 Tique wrote:
Originally posted by quinner quinner wrote:
Blow torch and 5 gallons of gas
Quinner helped me do this with my boat a few years ago. Turned out great.
Larry!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 6:48pm
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 6:08pm
or
What they said
kjo43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjo43 Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 3:28pm
An old credit card (or your wife's) works wonderfly as a gel friendly scraper.
cooperlacy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cooperlacy Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 12:59am
I just removed all the decals on my boat before buffing it out. I used a heat gun and a plastic scraper/putty knife and thought this combination worked wonderfully. I'll never use anything else. Once you hit it with the heat gun, the glue and vinyl soften considerably. Gel coat can tolerate quite a bit of heat. Unless you hold it in one spot for minutes on end, you'll have no problem. Use lacquer thinner to clean up what's left of the glue residue.
The only issue you might run in to is that the gel under the decals may look deeper colored if the rest of your gel is oxidized at all. If you're matching the decals exactly, this won't be a problem though.
Good luck,
Cooper
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 9:04pm
I was very careful and used a razor blade to remove my numbers and pinstripe. Some acetone cleaned up the goo.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 5:14pm
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 2:57pm
+1 on the eraser wheel. Quick and easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 2:47pm
A putty knife or razor is likely to damage the gel. A heat gun or hair dryer, if used judiciously, is fine. There are also eraser wheels (drill attachments) that are sold at autoparts stores that make quick work of old decals... but again, be judicious in its use so as not to burn the gel.
Follow up with an adhesive remover like goo gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 2:47pm
3M eraser wheel or heat (start low).
mousecreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mousecreek Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2012 at 2:42pm
Sooner or later the old registration numbers have to be removed, and the new ones installed on a new (to me) 94SN. Definitely not a job I am going to enjoy. The existing letters/numbers are white, presumably vinyl adhesive, and are stuck on quite well. Can I use a heat gun or hair dryer to help them come off and without damaging the paint/gel coat underneath them? Maybe a putty knife to get them off once the adhesive is loose? Does any one with experience doing this have any other suggestions for doing it in an efficient and clean manner? Thanks for the help.
