  New Posts New Posts RSS Feed - Need 4" coupler for 1" shaft
Nauti87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti87 Quote  Post ReplyReply Direct Link To This Post Topic: Need 4" coupler for 1" shaft
    Posted: July-20-2012 at 4:59pm
Also too, when I was removing it, as I would put pressure on the bolts, I would just sit a propane torch on it for a few seconds and it would move, then repeat. Sounded like a bell getting rung from the prop. Scared the heck out of me the first time! About every 5 min, ding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti87 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2012 at 4:53pm
No, the boat was from up north Wisconsin, no salt that I'm aware of, I do know this boat has never been apart.('87 2001)
I understand the puller issues that's why I did the socket/bolt method.
On my lunch hour I took it to our fleet maint shop. Put it on the press and gently straightened it back out. Then since the lathe was out of service, I got looking at the ammco brake lathe. What do ya know, the coupler is the size of the shaft on the machine. I chucked it up and trimmed .018 off of the face of the coupler and we're done. And now I know the face is square with the shaft. = )
Thanks for the replies, I love this site!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2012 at 3:47pm
Originally posted by Nauti87 Nauti87 wrote:
I did the 4 bolts with a socket in the middle. Just wanted to know if anyone had one laying around.
Thanks.
Jody,
Wow, that coupling must have really been on that shaft tight!! You used the correct method. Has the boat ever see salt water?
Regarding the gear puller, they pull on the OD of the flange so it's easy to bend it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti87 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2012 at 2:01pm
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2012 at 9:28am
Originally posted by Riley Riley wrote:
Once you press the coupling onto the shaft, how do you install in the boat?
Bruce,
You press it back off the shaft!! Then you need to use the heat shrink method to get it back on once the shaft is in the boat. Sorry I didn't mention pressing it back off. The exception is if you have the engine pulled, then the shaft can go in fore to aft.
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 11:16pm
search for my thread I walk you through the whole procedure. Petes link works or call skidim they have the coupler as well. Bout $85.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 11:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 10:10pm
It got a little warped when removing it. I can probably fix it, it's not cracked.
The proper procedure when R&Ring a shaft is to press the coupling back on the shaft, chuck the shaft up in the lathe and take a cut off the face. Chucking it by the shaft ensures it runs true to the shaft. DO NOT chuck the coupling on any of it's other surfaces.
What method did you use to remove the coupling to warp it? Hopefully not a gear puller on the coupling OD!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti87 Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 8:09pm
Call Billy or Karen
What happened to yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti87 Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2012 at 7:54pm
I'm looking for a 4" single tapper coupler for a 1" shaft, anyone have one laying around?
Thanks.
