Transmission Fluid Level |
Posted: July-20-2012 at 9:13am |
If you are loosing fluid but you don't see any external leaks, then it's your cooler. You can pull it off and run a pressure check on it. Hook regulated air up to the oil side and stick the cooler in a bucket of water.
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
There is a Borg Werner Velvet Drive Service Manual in the Reference Section.
It states 1.8 quarts if level or 1.3 if mounted at 15 degree angle. This does not include the ATF to fill hoses or Cooler. Have a look at the Service Manual and see if it helps. |
1980 Ski Nautique
1966 Barracuda |
74Wind
74 Southwind 351 Velvet Drive. 2 weeks ago after a while the trans slipped just a bit, so stopped & added fluid to top notch of dipstick. Ran fine for another hour...stopped for day, checked dipstick & fluid still full. (was with Morfoot that day)
Last week, checked fluid prior to start and was down a bit below half on stick. Added fluid to full notch, ran great 4+ hours, when stopped fluid still full. Tomorrow, I'd guess it's going to be halfway down again. Question is: 1) is this due to fluid temperature expansion/contraction or might I have a leak? 2) fluid should be checked hot, but I normally prefer to check oil & tran fluid before setting off. What notch level should fluid be when cold? 3) Also, what is total quart capacity of circa 1974 velvet drive, and how also what is quantity that is evident on the stick; i.e. from full top notch to no fluid showing what might be the volume amount? |
1974 Southwind 18
1975 Century Mark II |
