  New Posts New Posts RSS Feed - Tracking fins stripped
mars88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Topic: Tracking fins stripped
    Posted: December-21-2005 at 12:56am
99Sport-
I was sitting on the dock one summer day and was really boared. I had already "Zinged" the boat and cleaned the inside so I just decided to check out the underside and noticed the loose screw. It was dripping from the water behind the screw. I guess I was lucky to see it but with older boats it should probably be done more often.
mars
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2005 at 8:48pm
Trike,
Certainly wouldn't surprise me if through bolt was the standard in 80. Good to know.
BKH
Livin' the Dream
trikeaholic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikeaholic Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2005 at 5:40pm
my 80 are thru bolted and it appears factory. For the record....
1980 Ski Nautique
Ithaca NY
My Boat
99Sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 99Sport Quote  Post ReplyReply Direct Link To This Post Posted: November-16-2005 at 6:51pm
WOW!
I have been following this discussion and have found it to be quite enlightening. I do agree screws are the way to go.I am sure that 99% of the times that fins come off, it will be the result of striking imovable objects. Your prop, rudder, prop shaft and strut are going to be scrap metal a few hundredths of a second later.
I have only one question for Mr. Mars. Whatever pocessed you to check the screws on your fins anyway? In retospect I guess it was a good idea.
99Sport
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2005 at 7:53pm
Good input guys! I agree! So it sounds like the fins are not designed to break at the bolts. Couldnt it be made so that sideways its very strong, and front to back its designed to shear off? There is hardly any resistance on them front to back, so why couldnt they have a shear point so no matter how it screwed in, if hit, it would just break off. This would make replacment a snap!! By the way, I have no fins and not familiar with the construction to mess around with.
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2005 at 4:14pm
I personally have seen the hull damage from having them thru-bolted, Sheared the front 2 bolts, peeled the fin back and ripped the back 2 thru th hull. Big hole, major water leak! Luckly it was VERY close to a privte boat ramp and was able to be grounded on it before it took on to much water. I am sure the hull must be thicker at the shaft/rudder aera. Just like David's advice I would fill the old screw holes with foam rubber and reisn, or maybe epoxy, wait a few days to dry, reinstall the fins in new holes putting some 3M 5200 on the either stainless or bronze screws
NO LONGER A MEMBER
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2005 at 8:06am
In the FWIW catagory: The screws for the fins on my '93 SN would not be accessible if through bolted. If a larger screw was used, the holes in the fine would need to be enlarged. I believe the combination of glueing the fine to the bottom of the hull AND fixing the stripped screw hole with foam rubber soaked in epoxy resin would be sufficient.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2005 at 7:25pm
Jeff,
Not vouching for the accuracy, just reporting what I've been told. Like I said, some companies do through bolt (I believe the older Malibus and Centurions did so, but I'm not sure).
Physically, I think there are differences in the forces of an object hitting the prop/rudder/shaft. The shaft is angled
over a 1 or 2 ft run. If never seen a shaft
ripped out, but I have seen them bent up.
The prop will sheer off before it'll rip a hole in the boat. I suppose the rudder could rip a chunk out, but I've not seen it. Instead, the round portion of the rudder tends to bend or sheer.
The Fins on other hand, are pretty much an immovable object, dead center, and typically right under the heaviest portion of the boat. If you hit something with them, you hit solid. So I think the theory is that the bolts will stay with the fin and rip a big section out of the bottom of the boat. With the screws, there is a better chance that the screws will be ripped out of the fiberglass. This would cause some damage to be sure, but not as severe as if a big section were ripped out.
The fins really shouldn't loosen up. They use very adhesive, as well as the screws.
In any case, CCs, at least the more modern CCs, use screws. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2005 at 7:10pm
Why should thru bolting cause hull damage if done properly. Shouldnt the fin break before the fiberglass of the hull? Struts and rudders are thru bolted, and most people hit things and most of them can just be replaced. Assuming the hull is thick enough, and a large enough backing washer is used, I would think it would be a lot less hassle than worring about flying down the lake and having a fin loosen up, fall off and slam into the prop. The only thing I can see as negative is that if you did rip off a fin, no water would enter the hull. Any other input??
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2005 at 4:52pm
I dont like the sound of through bolts now. I think i'll stick to screws. I think i'll look for a wider screw.
mars
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2005 at 10:05pm
I know some companies do thru bolt. I've been told the theory behind the screws is damage control. If you hit something with a thru bolt system you might tear a big hole in the botom of the boat. With the screws, you'd likely have less damage.
It makes sense, but I don't know. I've seen some fairly severe damage with the screws.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2005 at 8:06pm
I agree that thru bolting is way to go if access is available to tighten them!!
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2005 at 7:35pm
Wouldn't it be simpler to just drill through the hull and use a new flat head stainless machine screw, couple washers and a nylok nut should do it. The fins on my 81 are through bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2005 at 7:08pm
Is it possible to use a ss flat heat machine screw where you can drill and tap and install ss thread inserts (helicoil). You might need more than one insert if you have enough depth. They work amazingly well in soft aluminum, but honestly, I have never tried it in fiberglass. If theres enough depth for enough threads, it should work, but I cant be certain. I do know that on a fiberglass antenna mount we use, they tap 5/16-18 about one inch(with no helicoil) in the fiberglass, and I can tighten it down to the point of bolt failure. I would use a course thread if I were to try it. Any one else have any input to this??
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2005 at 11:49pm
If the screws are into fiberglass, clean the hole and then dip the screw in some epoxy and install. Although you have to knock them off with a hammer, it's probably a lot of force on the fins when the boat is turning so I'd resin the things back in.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 8:36pm
On the three I've done, all were screws into the reinforced fiberglass down the center of the boat. Going into the first, I was expecting thru bolts, or at least tapped
holes, but that was not the case.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 6:56pm
I should have double checked my previous post for typos before clicking "post reply."
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 6:52pm
Im not familar on how tracking fins bolt on since I dont have them. Is it a sheet metal screw in the fiberglass, or is is a tapped hole into something? This just has me curious!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 3:52pm
I'll be interested to see what some of the others
say. If it were me, I think I might try a slightly wider screw, but not a longer screw.
BTW, the adhesive that comes from the factory
is itself very strong. I've changed out fins
on three boats, and in every case we has to pry
the fins off, or bang them off with a rubber mallet even after removing the screws.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 3:26pm
The screws were very loose when i checked them earlier this summer and seemed like they were barly grabing. So i took some sylacone and filled the hole and then put the screw back in. They held the rest of the summer but I was wondering if i should get longer screws or something else like go all the way through?
mars
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 1:27pm
Do you need to get them out, or is it that you just don't like the way they look?
If the former, probably a pilot hole and easy
out will do the trick. Just don't drill too
deep. Perhaps back out one of the good ones
to make sure you know how deep you can drill.
If the latter, I'd say, personally, just don't
climb underneath the boat and look at them.
BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote mars88 Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2005 at 11:43am
My nautique's tracking fins have a few screws that are stripped. What do you guys suggest i do?
mars
