Steering sticks |
Posted: July-25-2012 at 12:14pm |
Marty,
Thanks for that fantastic info. I'm ordering a Slap Chop and a Grill Glove today!! |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
That whole assembly doesn't look "New" to me. If it's been sitting on a shelf- more that likely it's got hot and the grease has liquified a little and may have leaked out some. I'd do like PeteB said and open that helm up and clean and grease it.
Also the length of 16' seems a little suspect to me. As for the horn killing the motor-- I'd be checking the wiring in the whole boat and make sure my fire extinguisher is charged. |
Get the Ohm meter out and check the horn. If you get a low or near zero reading, you have a short that's pulling down the volts to the dash and the ignition system. BTW, you had better check to see if your horn is fused or is on a breaker. |
jo-e90
Gold Member Joined: March-16-2011 Location: Midwest Status: Offline Points: 659 |
Thanks,
I will take the helm apart this week sometime. Also, my horn does not work as a horn, when I press on it, it kills the engine instead of honking. |
1997 Sport Nautique
I'd open up the helm and check the gear that engauges the rack on the cable. If it's sticking in the same spot with every revolution of the wheel, then I'd say somethings up inside. Clean and grease.
jo-e90
The steering in my 92 ski is not smooth as it turns with some resistance every time I turn the wheel. It will stick at certain points on every steer.
New cable was installed and replaced rudder packing and greased shaft. |
1997 Sport Nautique
