  New Posts New Posts RSS Feed - speedo?
speedo?
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Topic: speedo?
    Posted: April-03-2004 at 4:00pm
i would like to see a picture of that. see if you can get a name off the pickup or speedo housing. i think these where on a few late 90's products, but i have never seen one up close and personal.
you might look at some of the humingbird or depth finder stuff and see if you can find a speed pick up. moi would take it out, plug the holes and sell it on ebay in 30 years. just kidding. let's see a picture.
danman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danman Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2004 at 2:56am
I have a 78 ski nautique that has dual airguide speedos that work fine, it also has a single speedo that is mounted right in the middle of the dash - it says ski nautique on
it, and it is wired to a pick up in the hull of the boat on the rh side. There is a hole in the hull with a a fancy array of plastic plumbing fittings, there is suppossed to be a paddle wheel that mounts in this hole and spins when the boat is moving. The tiny axle that the paddle wheel spins on is there, but no paddle wheel. I called Woody@secc, and he told me this was not factory.... if so, does anybody know where I can find this paddle wheel and a seal for the housing cover?
