Lake Lanier mechanic for 86 Ski Nautique 2001 |
Post Reply | Page 12> |
pepatrick
Senior Member Joined: July-26-2012 Location: Cumming, GA Status: Offline Points: 102 |
Posted: August-05-2012 at 12:56pm |
Just a puddle of water from cleaning sitting on some oily deposits. It is not fuel.
BuffaloBFN
FWIW - I know Greg pretty well and he's super freaky about fire. I'm sure he would've looked the carb and fuel path over carefully; especially after seeing the discolored areas Kris noted. If he found anything, he would've explained it to Pep with emphasis on what could happen to him and his family.
Lots of newbies lately; this might be a great place for some reminder pics? |
Dreaming
Pep - it may just be the paint on your manifold, but it appears that there is a puddle of fuel under the carb inlet line. certainly something that needs to be addressed ASAP if it is fuel if it is the color of your manifold.... carry on
pepatrick
Had it out on the lake all day today. My daughter and son knee boarding and yep...that "t" word. She ran strong all day and seemed to get even better as the day went. I love the way that 351 sounds. Before I took it up...I pressure washed the motor...obviously covering the important parts. Its still not super clean, but far better than it was consider probably had never been cleaned in 26 years.
BuffaloBFN
The shaft seal doesn't take long; give me a ring. The steering cable has a longer throw than standard so no West. Several have posted what and where to get it. Barring a cat's-a$$-trophey, those aren't too bad either.
pepatrick
Got a few things we need to tweak on this. Hopefully you can provide some assistance on this. Perhaps this winter...the steering cable needs replacing and even sooner the stuffing box needs to be stuffed. Other than that..It should be good for the rest of the season. Most the bolt on stuff, I should be able to handle.
Philip |
BuffaloBFN
The trick is learning to stay ahead of them rather than dread the day they show. |
pepatrick
Yep..that was done too. Just spent 3 hours out on the lake pulling my son and a couple of his friends on knee boards and wake boards. She never skipped a beat. I believe this set of gremlins has been solved. Now I prepare for the next ones...LOL
Don't forget the wiring harness plug(s) at the engine. Since under the dog house get pretty damp at times, I've found plenty of green in them. I picked up something like 3 volts up to the dash when I did my Tique.
pepatrick
I was impressed...when screwing the seat down..I only had one screw that didnt want to bite. The rest went it very tight.
pepatrick
Got the bugger running great today. As Greg mentioned in an earlier post, someone did some rewire work and did a pretty good job. Wires are neat and tidy and wire tied so nothing is jiggling around under the dash. I did disconnect the main ground under the dash and cleaned the connector with an emory board, added some dielectric grease and screwed it back into place. I disconnected the two main harnesses under the dash cleaned the connectors and added grease. Took out the ignition breaker and key switch..cleaned them up and added some dielectric grease to them and shot a little WD 40 to loosen the key switch up.
Took her out on the lake and fired it up for a test run. Volt meter was reading 13 volts and the 351 sounded better than before...just more consistent at idle. Decided to go for it and took a 20 minute run on the lake. It ran flawless and all the gauges are much more consistent. They were not bouncing around like before. Keep your fingers crossed. Again..thanks for all the help. You guys are awesome. |
pepatrick
Greg is just trying to make feel good about the engine because of all the other crap that needs attention...LOL
BuffaloBFN
Another note: His engine had whistle clean oil in it and the engine ran very smoothly. I bet his compression is within a few points.
BuffaloBFN
Philip, something I didn't mention is to put that flame arrestor in a can of solvent. Along with that, the pulleys need to cleaned and straightened. There's all that belt dust that will work its way into the engine-not good.
While that's important, it'll keep till winter unless you have the time. |
BuffaloBFN
Pete, I'm not sure who he had it with yesterday. He pulled it out of that shop when he brought it over here. They were at least a week getting to it.
This boat spent its life on Lake Burton and has had a good mechanic working on it. I won't say a lot of extra effort went into it like cleaning, but shops seldom do that. The only non-original thing I saw was a bus bar under the dash. What little of it I could see was a very clean install. To your boat shop comment...what froze me was it was dirty...ewww. I think he has a front and/or rear main leak. I also suspect it isn't leaking much. It has the look of a slow leak over time. |
Well, we now know that "mechanic" is not someone you want to take a boat to! He didn't do anything for you and Greg did! Greg, you need to open up a shop for boat/engine repair! Phi;p, Who was this "mechanic"? Telling us would prevent someone making the same mistake. Did he "fix" anything? |
BuffaloBFN
Let's let the dog days pass, and yall pick a w/e. I have to finish 'growing back'. Thanks for the kind words Jim. |
BuffaloBFN
As yall can see from my quote, all I did was channel CCF. Most welcome Philip. Before you go crazy with those cables, see if West has some high dollar degreaser. Also note in Pete's post that you'll need to clean up that mounting plate. Everything we bypassed is suspect. Sorry we didn't get to the actual tune-up. Bring it back next week if you like. |
pepatrick
I am in the middle. My family has a house boat and pontoon boat up at Port Royale. Im not far from either end of the lake. Bald Ridge is close and so is anything around Hwy 53. I am about 4 miles north of exit 17 on 400...so just about any place is pretty good.
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
It is a testament to the caliber of our CCFan members. Had a feeling Greg would be a big help.
Phillip, several of us are at Lanier on a regular basis. Usually on the south end. Of course, the great hospitality and smooth water up at Little River is sure hard to resist. Probably rendevous up that way again soon |
kapla
I think you owe us some pictures of the boat!
<a href="">1992 ski nautique
pepatrick
Greg...Thanks for helping out today. I some how got side tracked on the way home and ended up by West Marine in Flowery Branch and picked up the 2 gauge cable and the appropriate fittings. Should have it knocked out tonight or first thing in the morning running the cable. I really do appreciate the help. Thanks you so much. Hopefully there will be another mini CC event on Lanier this year. I will definitely be there.
BuffaloBFN
It looked like the original as with most of his boat. He has a new coil, ballast resistor, and battery; but most of the boat is as it left CC. |
BuffaloBFN
Thanks Billy, and Tim, and Pete<---in no particular order. I sent out a few lines and got all of you at once!
I knew the juice was looking for a place to go...it just didn't click in my head. Stagefright maybe? I bridged his neg battery cable and bang, started right up. Shades of the 50th Masters. He has a few other things to do, but it's a really nice boat. Picture a time capsule that's been used. |
Greg,
Did he tow it over to you? Check the volts to the start relay coil. Also, The base on the relay is the ground path so check it out. Between the relay frame and the block, you should get a near zero Ohm reading. Even with the buzzing, is the relay pulling in all the way? You can tell by getting a volt reading off the cable running to the starter. Did he put a cheap "Autozone" relay on it? |
BuffaloBFN
Philip's solenoid is buzzing. He's still here...any ideas?
He does have a new battery and we replaced the solenoid; still buzzing. |
pepatrick
I will probably do that. I have it over at a mechanic now...If I dont get anything back from him by tomorrow, I will pick the boat back up. Thanks for the help..
jimsport93
Phillip, take Greg up on his offer. You will pick up a lot of knowledge about your engine and most likely solve your problem.
And....have a great CCFan buddy at Lanier! |
BuffaloBFN
FWIW-It wouldn't hurt to post this for the group. If you did already and I missed it, please link it for me.
On your brief description, I'd say it's a fuel flow problem. There are always other possibilities though. |
pepatrick
What part of Gainesville? Think you can figure out why its dying.
