Drive Shaft Removal |
srbranum
Senior Member Joined: March-06-2010 Location: Huntsville, Al Status: Offline Points: 376 |
Posted: August-06-2012 at 12:36pm |
I only pay for liability insurance as well, $100/year with Progressive. I got a quote one time from somebody and when I told them what kind of engine I had, how old it was and the length, the price was hilarious. I just have to do most major work myself or with a lot of help and hope it does not catch on fire, fall off the trailer or get stolen.
By the way, I had about half the trouble you had earlier in the summer with similiar circumstances and with everyone's help, especially Gun Driver, I just got back from a two week trip to the lake with lots of TUBING with the kids and it works fine. |
I have to keep her running 'cause I can't afford a new one
I only carry liability too. After all these years why make the insurance companies richer.You have to be disciplined enough to take that money put it away and pay for your own mistake instead of betting against yourself. Just my 2 cents
RedandWhite73
Senior Member Joined: October-03-2011 Location: Minnesota Status: Offline Points: 135 |
I had arranged for insurance, but the title transfer hadn't been completed at that point, so it wasn't yet in effect. Although I actually had it out twice (very briefly) before I wrecked it. I hindsight it was pretty funny when I crashed it. I was the last boat on the lake, in late fall MN. I went to take it out of the lake and hit the rocks. I took my first stroke with the only paddle on board and it snapped in half. I had to wait an hour and a half until a randon fisherman came by and towed me to the landing. In hind sight, I should have packed more than two beers.
Anyway, I attached a picture. I had a whole winter to get over it and a wedding to pay for in June, but now I have some time and a little cash and am looking forward to getting her in working order. |
Plus one one the insurance. If none, you are stupid. Sorry!! |
SNobsessed
Dan - Don't know if you have insurance, but your event would have been covered. You can legally collect for parts & labor then do the work yourself (covers the deductible).
I recommend insurance, if nothing else for the liability. Mine costs $200 per year, great pc of mind. |
Dan, I too am sorry to hear about your problem with the rock bar! Yes, there is a point where prop repair cost exceeds the cost of a new prop. You may want to check out the new CNC props anyway and give that old baby some new performance. Where are the pictures???? |
baitkiller
Oh God... I just threw up a little. Sorry to hear about that.
RedandWhite73
I bought a 73 Southwind last fall, while on my maiden cruise all the buoys were pulled. I ran into a rock pile and trashed the drive shaft and everything behind it; shaft, strut, prop, rudder-sheared off, and I had to repair the fiberglass where the strut bolts in. It has been a very interesting learning experience so far.
Is it common that a prop can be damaged beyond repair? I took it to two places and both said it was beyond repair. |
Dan,
I forgot to ask, why are you pulling the shaft? You haven't filled us in completely! |
I'm sorry to hear the issue confirmed. OK, the ARE system is damn close to the price of a new shaft and coupling so go with it. Give Billy or Karen a call and ether will set you up with it. The R&R is so easy, you will appreciate it even though this is the first coupling you have pulled. The appreciation would even be higher if you got the the put it in the oven at 550 for the heat shrink install stage!! |
RedandWhite73
Unfortunately, I think I may have made that mistake. I got the coupling about 1/2" downward on the drive shaft. I guess I like to learn the hard way. Do you have any recommendations on getting a replacement drive shaft on a budget?
Dan,
Did you start pulling the coupling before you loosened the sq. head set screw? If so, and since it goes into the counterbore in the shaft, I'd say the bottom of the screw is pretty trashed and maybe the shaft itself as well. |
baitkiller
Yes Dan that square plug is set screw that is tightened into a small counter-bore on the shaft. It may take oxy-acetylene but it must come out.
I use some Snap on 410 parrot head pliers usually and it seems to really do the trick. You probably just need more heat. Blue can propane will never do it. MAPP, maybe. Of course remember to watch Professor Petes alignment video and check your strut bearing. If you are replacing the shaft then just cut it off and order an A.R.E. kit. Good luck. |
RedandWhite73
I've been having a heck of a time getting the drive shaft off my 73 Southwind. I am using the "deep socket" method with four hardened bolts. There is a square head sticking out of the coupler, does that need to come out before I can do the "deep socket" method? And if so, does anyone have any recommendations for getting this bolt out? I have used liquid wrench and a torch, but it still wont budge.
Thanks, Dan |
