  New Posts New Posts RSS Feed - Run the bilge blower
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Topic: Run the bilge blower
    Posted: August-15-2012 at 3:24pm
This is one reason I "unplug" after use, this make me have to open the dog box to "plug" before I launch. I also run the blower from the driveway until I get out onto the main part of the lake. (well into the 5 min mark from driveway to turn of the key)
What a mess.
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 10:50pm
I got in the habit of running the blower from the time I hit the ignition switch until I shut down the boat. I know it is unnecessary while moving but it doesn't drsaw much and doesn't hinderany performance. I lift the hatch before starting also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 10:09pm
Alan,
I wouldn't be surprised if this Chris developed a hole in the tank. The boat wasn't in the greatest shape. I know the present owner and he called me on the Memorial day weekend. He wasn't too sure but felt the log had ripped off the inner keel and wanted me to fix it. That repair could be quite extensive depending on how much rot is found. I suggested someone else since I sure wouldn't a repair to come back on my reputation.
BTW, the Chris was originally owned by the late John Lamon Sr. of Watercraft Sales. It was one of those family heirlooms that had been passed through from a previous generation. Back when I was at Watercraft in the late 60's, John brought it in one day for me to varnish the transom. I finished the job, put it in the water but our mechanic parked a Donzi sweet 16 behind it. He neglected to tie it up secure so the bow of the boat proceeded to trash my fresh transom job. John was heart broken to say the least.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 9:12pm
Well if it was a fuel leak the blower probably wouldn't have done enough to clear the fumes in the short time that most run it and it sure wouldn't plug the leak for you. Real answer is you have to lift the doghouse or engine bay doors or whatever you have and take a sniff. If you smell gas there's a problem so don't turn the key until you find the source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 8:47pm
The blowers where never installed in older boats. My 54 nor my 64 are equipped. We have always learned to lift and smell! By the way, I'm not aware of a 6 volt blower anyway. Bilge pumps yes but not a blower.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 8:28pm
after all looks like those dog house hand warmers aren´t a bad idea for the careless boater....
<a href="">1992 ski nautique
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 8:25pm
A good reminder to us all to run that blower and lift the hatch, every time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 7:33pm
Seb,
They did air lift one person down to a larger hospital with a burn center. As it turns out, he was lucky and the burns weren't serious. I understand that 3 fire departments fought the fire. None were able to get any equipment down on the lake side due to the steep embankment and the boathouse blocking access, so all the water was tanker-ed in and lines run down the hill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 7:13pm
wow that´s terrible! just material damage or were souls lost?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2012 at 7:11pm
We lost one of the old two story 3 wet slip boathouses last Sunday up north. It was built in 48 and housed a 22' Chris which was the cause of the fire. There must have been a fuel leak and the owner didn't open up the dog house to check. Some of the components used on the Chris/Hercules were not ignition protected.
