trailer information |
The Dude ![]() Platinum Member ![]() ![]() Joined: October-19-2004 Location: Houston Status: Offline Points: 1338 |
![]() ![]() ![]() ![]() ![]() Posted: December-16-2005 at 6:52pm |
I have 95 Sport Nautique, but it's on a Dorsey trailer. Sorry I can't help. I think it totally sucks that CC can't give you any help. Are they screwing around? What kind of service is that?
tjsal ![]() Newbie ![]() Joined: December-03-2005 Location: Canada Status: Offline Points: 10 |
jwkc, thanks so much for the information. I can finally bring my nautique home where it belongs. Thanks again.
jwkc ![]() Newbie ![]() Joined: December-13-2005 Location: Canada Status: Offline Points: 1 |
Hi,
I have a 1994 Sport Nautique trailer. I can barely make out the numbers but I think this is what they are: GVRW 4550 lbs, GARW 4660 lbs, tires ST225/75R15 Hope this helps. |
87sn2001 ![]() Newbie ![]() Joined: October-27-2005 Location: Canada Status: Offline Points: 22 |
the only thing I can help you with is my B.C. regi. states the GVW in kilograms (004440kgs)...and like your trailer there is nothing left of the origanal decal..it's an 87 cc trailer
Thanks to all for your help so far. According to the VIN Correct Craft did manufacture this trailer. They, correct craft, also sent a letter stating that their were no recalls on this trailer. My government is requesting Gross vehicle weight, Gross axle weight, stock tire size and inflation pressure. This information is located on the sticker found on the inside frame rail near the hitch. Mine is illegible. If anyone has a similar 1990 - 1994 trailer please help with this information. Thanks for your help.
mrese ![]() Groupie ![]() Joined: February-18-2004 Location: Al Status: Offline Points: 93 |
I have a 89 3DV CC single axle trailer. GVWR / GAWR = 4660.
It came stock with H78-15 STD tires with 65 PSI cold (max load carrying capacity = 2,330 lbs) Now I run ST 225/75 R 15 tires, still at 65 PSI. |
jbear ![]() Grand Poobah ![]() ![]() Joined: January-21-2005 Location: Lake Wales FL. Status: Offline Points: 8193 |
tjsal; Not to correct C/C but my '93 came with a Ramlin trailer under it. They were built in a building next door to the factory on Orange av in Orlando. I believe the short-lived 176 was built in the same building. Maybe the mix-up is why there is no records. I'm sure someone on here has the info you need..........john
"Loud pipes save lives"
My trailer was manufactured in May of 1994 by Correct Craft. According to Correct Craft they sourced out their trailers in 1995 but have not kept records for 1994 and before. They have been contacted numerous times but have offered no help. If someone could look at their own trailer, single axle, 1994 or earlier, that would be much appreciated.
tjsal |
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
tsjal,
I believe CC stopped production of trailers in 91 or 92. I'd be very surprised if you have a factory trailer under your boat. Can you possibly post a picture of the trailer. In the western US, most boats are on zieman, DHM, or Sport Boat trailers. In the east they tend to use Ramlin and a couple of others. If we can figure out the brand, you can probably get the info from the manufacturer. The numbers you are looking for are the Gross Vehicle Weight ratings. Mine is 5000 lbs for a tandem trailer. If you assume your trailer has the proper tires on it, you can get the numbers off the tires themselves. Most have 14 inch tires with a cold tire pressure of 35lbs. The tire info would have also been on the sticker which you apparently can't read. BKH |
Livin' the Dream
Would someone please help? I have a 1994 ski nautique on the factory trailer. In order to register the trailer in Canada I need the GWVR(GVWR?) , GAVR(GAWR?) and tire size with cold inflation pressure. This information is located on a sticker affixed to the inside of the trailer near the tonque. On my trailer this info is illegible. Thanks so much for your help.
Terry |
