Motor mount and water pump pulley |
Got Tiques
Senior Member Joined: February-27-2009 Location: Scotia, NY Status: Offline Points: 427 |
Posted: September-07-2012 at 12:15am |
Ben,
I measured the pulley, however it is 6-3/8", not 6" per your email on the OD of the double sheave pulley, you may want to recheck your measurement, because it mounts on the engine circulating pump and is standard for Fords. But I cant sell it yet, as I haven't found a spare in my inventory for my motor. The pulleys fit fairly close together, but you may want to check your bottom pulley size if it is hitting the upper pulley. I think they are both 6-3/8" OD. Let me know what you find. Give me a few days, and I'll get back to you on availability of my pulley. Thanks, Todd |
thateb
Groupie Joined: August-28-2012 Location: Pierre, SD Status: Offline Points: 52 |
Awesome! You are becoming my favorite person Todd!
Got Tiques
Ben, I'm sure I have the pulley for a 302 that mounts on the water circulation pump that carries two v-belts. I'll measure this afternoon for 6" and email you back.
Todd Benjamin |
thateb
The rubber in the motor mounts in my 76 tique is junk and i need some new stuff. also the double groove pulley on the water pump (302) is 1/2 inch too big and causes interference with the crank pulley. I need one that is 6 inches in diameter. Thanks for looking and helping.
Ben |
