Boat dies while accelerating |
Post Reply | Page 12> |
Author | |||
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
Posted: March-29-2014 at 12:04pm |
I have the same drop @ my dash. 12.75 @ the battery, but only 8.5 @ the volt meter (verified by a hand held volt meter between the purple switch pwr and the gnd terminal block). I didn't think the measure the output of the dash ignition switch. If I have 12 to it and 8.5 out, it could be the culprit.
Tom, which part did you buy? I didn't see the breakers with a metal button, just plastic. |
"I don't know what the world may need, but a V8 engine's a good start for me"
Bri892001
I'm more trying to figure out how the dash is getting power now.
I suppose the best thing to do, is remove the switch and test it for continuity. Both with the button pushed in, and popped out. Then you can tell if it is the switch. |
tbeard
Senior Member Joined: April-26-2012 Location: Fort Worth TX Status: Offline Points: 379 |
In normal operation...when that breaker is working there is no power to anything. Tis is the ignition breaker (20 amp)
Thanks.......Tom
Bri892001
I have an accessory breaker that likes to "be broken" in the on position. It takes some finagling to get it to pop back out.
Is yours popped in? And, when you say "everything" are you talking about things that would normally need both the ignition breaker and the key switch to be on? Or, just normal things that need the breaker, like the horn switch, and bilge switch? |
tbeard
It is not just the clock running with the breaker off....everything works weather the breaker is pushed in or out. I assumed when a breaker was bad the power could not pass through it....is that correct????
Thanks.......Tom
Bri892001
Agree with Tim.
Also, from another thread, I saw you've done some rewiring. Any change the clock got hooked up to the input side of the breaker (constant positive) instead of the output side (switched positive)? |
Morfoot
Tom it's not unheard of for a breaker to go bad. Once you bust out the voltmeter you'll know for sure.
tbeard
We got the boat running last week and everything is working...engine, horn, bilge, blower, lights. When not in the boat I always turn off the ignition breaker off so the clock is not running.
When I started working on the boat last night I noticed the clock running with the breaker off. So now the main breaker does not close to keep power from running through the dash. (Power is there weather the breaker is open or closed) Is that common with a faulty breaker or could I have power feed from the Ballast resister or solenoid? I plan to go back to the shop tomorrow and take my Volt meter to start troubleshooting. |
Thanks.......Tom
BuffaloBFN
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
TX Foilhead
[QUOTE/] Ryan (SN206) will give me a hand....[/QUOTE]
Hope and Change! |
tbeard
No readings yet...the boat is still in storage at the river. I need to bring it home next week where I have my tools and a place where I can work on it. Ordered the breaker knowing it would take a few days to arrive. Ryan (SN206) will give me a hand....hopefully
Thanks.......Tom
Tom, Joe and I aren't "going at it" We are just friends having a very interesting debate!! So, you got voltage readings (for drop) as well as the amp load that was going through the breaker. I'm glad to hear that since I would hate to label a fellow engineer as simply as another "parts changer!! What was the drop and amps through the breaker? It sure would help others with the possible same problem who have access to a VOM. |
tbeard
While you guys are going at it I ordered my new circuit breaker for the ignition today from nautique Parts... Hope that fixes the problem until I can evaluate the wiring. :)
Thanks.......Tom
JoeinNY
Not stupid, just stubborn..
We are talking about the run circuit of a boat here (which may contain a bldc stepper motor if equipped with non drive by wire perfect pass but not one that would draw more current at less voltage) .. if you want to get into the applications of brushed vs brushless and then onto ecm motors vs. permanent magnet synchronous, vs internal permanent magnet synchronous with flux weakening then I am your huckleberry.. but if you want to get into the most fun stuff we would need to take it offline and you would need to sign an NDA… My points remain valid.. there is only one ciruit on a correctcraft where increased resistance may at some points cause increased current draw (and even then it is decrease increased max current but is increased power consumption) |
Joe,
You need to clarify DC brushed or brushless. They do react to a voltage drop differently! I'm not as stupid as you think I am!! |
JoeinNY
Of course but that is a very limited and transient situation, that as you state - in a boat can only be found in the starting circuit. Not even with the other motors that can be found in a boat the such as the bilge or blower… they have a defined torque speed curve and with any voltage significant enough to cause their operation they will move slower and use less current at the lower voltage. This is different that with AC motors because of the set frequency of the ac current and the design of the motor tends to as a rule draw more current when you drop voltage below the design operating voltage of the motor at that frequency. The situation remains… in this case Pete is all wet.
SNobsessed
As one who knows only enough to be dangerous, there is a case where Pete is right - If the wire is feeding a motor, then increased R may result in lower RPM & lower back EMF, thus creating more amp draw. I realize this isn't the case here as it is not the starting circuit that is in question.
pepatrick
Senior Member Joined: July-26-2012 Location: Cumming, GA Status: Offline Points: 102 |
There are those who know...and those who think they know...
JoeinNY
Ohms law actually states the exact opposite, current (amps) decreases as voltage decreases. You have been playin with ac motors for too long...
Joe, Get back into the basic Ohms law!! As voltage decreases. the amps/watts go up! |
JoeinNY
I maintain that Pete is still all wet on this. There is more waste heat but not more current created from the increased resistance of any of these loads. The reality is not different than the equations. Breakers get weak from internal corrosion of simple mechanical cycling of the materials.. additionally the contacts within the breakers can corrode and have thier own increasing contact resistance which will heat up the breaker to a point where it will pop at a lower than rated current... but too small a wire aint gonna incease the amps going to the circuit fed by that wire.. |
What's the load? Without knowing the amp load, just saying the "wires looked small" is meaningless. |
tbeard
I looked under the dash a while back and did see a black terminal strip with blacvk wires attached to it. Mabey CC or a previous owner installed that. The wires looked small.
Thanks.......Tom
pepatrick
I think the 89 BFNs might be a little easier to wire as the dash wiring may be more easily accessible. The 86 SN was just easier to lie on the back and wire away...
pepatrick
In my case..it was not tripping the breaker...I think corrosion was not allowing for a good connection. When I turned on the blower, bilge pump or nav lights my real voltage (volt meter) would drop to below 10 volts. The engine would run, but the gauges would jump all over the place. When I would run full throttle it would run great for a minute or so and then die. I would have to use pliers to start it through the solenoid and it would just turn over. After it cooled off for a while it would start back up. I also learned later on if I banged on the ignition breaker it would start up with the key. Once I rewired and cleaned up the breaker, I have not had a problem with the boat since. I am getting about 13.7 volts +- (volt meter) when running now. I am getting very little drop if any when nav lights, bilge or blower is on. Some times the blower will drop it a little, but not enough to worry about.
If you have any electrical back ground, these boats are not that difficult to rewire. It just takes time on your back under the dash. I pulled the front seat out and loaded up with blade connectors, ring connectors and lots of 14 gauge black, red and purple wire. The PO of the boat already had + and - terminal blocks screwed to the back of the dash so that made wiring considerably easier. |
BuffaloBFN
Thanks Pete. I get the equation and the math...it's the translation into real world applications that I'm sorting out. It's all the fault of some guy named Grob. |
tbeard
OK....Give me a week or two to get the boat home and get started on it. Thanks Pete, Greg and Philip
Thanks.......Tom
Tom, Yes, get us the voltage readings. Even better would be the amp reading that's going through the ignition breaker. |
tbeard
I am terrible at electrical troubleshooting and analysis, so in simple terms is this what I need to do.
1. With boat running get the voltage readings off the battery. 2. Get same readings off the wire connector on the ignition circuit breaker, coil and electrical choke....while boat is running. 3.If there is a significant drop in volts replace the wires. (I will post the readings next week when I bring the boat home) 4. Replace the ignition circuit breaker for good practice. |
Thanks.......Tom
