  New Posts New Posts RSS Feed - VR1 Synthetic?
VR1 Synthetic?
rfarkash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfarkash Quote  Post ReplyReply Direct Link To This Post Topic: VR1 Synthetic?
    Posted: September-24-2012 at 3:54pm
Thanks for the vote of confidence. Will let it sit as is and not worry about it.
BTW - i revile searches as well :)
Thanks
Ron
Ron 1989 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2012 at 9:37pm
Ron,
I feel you will be OK. There are times when many will mix the two together and in fact, when you buy a "semi synthetic" that's exactly what the lube guys do. I have done searches that reviled it's not a problem. The key is the ZDDP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfarkash Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2012 at 8:11pm
Any difference between VR1 20/50 and VR1 SYNTHETIC 20/50 other than price? Going through winterization and mistakenly mixed 2 qts of each. Have always used the conventional in the past because consensus was ZDDP levels were good. Assumed the different bottle colors was just a marketing thing until I read closer. If there is a real difference (particularly zinc content), I have no problems draining and refilling, just want to confirm either way. Didn't find too much on a google search other than the hot-rod guys.
Thanks
Ron
