  New Posts New Posts RSS Feed - 1984 Ski Nautique
1984 Ski Nautique
cphase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Topic: 1984 Ski Nautique
    Posted: October-27-2012 at 2:45pm
ROLL TIDE ROLL!!!
Thanks,
Jeff
82 SN
Arch Linux
parrott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parrott Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2012 at 1:28pm
You are from Tuscaloosa. Quit playing with the boat and get ready for a big game tonite!
1999 Air Nautique
1992 Nautique
1978 Nautique
Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2012 at 9:50am
Thanks, I will clean and tighten all connections from the switch to the starter.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2012 at 9:28am
Check connections 1st - they need to be tight & clean. Corroded wire? Bad battery? Bad breaker? Use your VOM to isolate the weak component.
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2012 at 9:28am
Possibly a corroded terminal
Brian
Check connections 1st - they need to be tight & clean. Corroded wire? Baf battery? Bad breaker? Use you VOM to isolate the weak component.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2012 at 9:13am
I am having igniton problems. i turn the key to start engine and the voltage meter shows less than 12 volts and nothing happens. I try a minute later and it shows 12 volts and the engine starts. What is causing this? The battery is fully charged, so I know that is not the issue.
