  New Posts New Posts RSS Feed - Thank U...
Thank U...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Thank U...
    Posted: December-02-2012 at 10:38am
Originally posted by eljayrx eljayrx wrote:
Originally posted by Donald80SN Donald80SN wrote:
Some of the Pink RV Antifreeze you do not mix with water. You use it at 100% strength. You may want to make sure it was not RV antifreeze if you added water.
We have one guy on the site that has -100 ( F) Protection special antifreeze.
Donald
.DRAINED the whole system.. Then added -50 anti freeze ,for engines.. Bought it at West marine..If this does not work then.. o -well. aLL SHOULD BE FINE.. .....
-100? wHERE DOE THIS PERSON LIVE? RUSSIA?
The member with the -100 was working at a marina. Because they used a half a*** back yard quick and dirty method of winterizing (no drain and pump through only), they were using the -100 and crossing their fingers. There was plenty of debate here on the site and we gave him plenty to think about. He hasn't been on since I'd say this last spring. I'd guess in spring, that marina had a frozen block issue or more!!
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2012 at 10:00am
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2012 at 8:59pm
Donald
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2012 at 10:16am
Originally posted by SNobsessed SNobsessed wrote:
Linda - We like the full details - was there antifreeze in the engine when you drained it?
Yes! Redish colored ,mixed with the water....So , some did make it to tthe block. as it should..I guess. or as told it would..
   I used a -5o protection for engines..
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2012 at 10:14am
Originally posted by 62 wood 62 wood wrote:
Originally posted by 81nautique 81nautique wrote:
Hollywood?
Is it all starting to fall apart?
What is falling apart?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2012 at 12:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2012 at 8:31pm
No thank you's needed. We all have needs.
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2012 at 5:51pm
Hollywood?
64 American Skier
62 Classic..
73 Ski Nautique
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2012 at 12:44pm
Hollywood?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2012 at 12:08pm
For all ur help--with understanding the thermo- by pass system.. all is good! drained out and added anti freeze---Thanks again for your time and help!
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2012 at 12:05pm
