damper plate PCM 15 spline |
rmm025
Senior Member Joined: July-20-2009 Location: West Monroe, LA Status: Offline Points: 148 |
Posted: January-24-2013 at 4:29pm |
Still looking for an exhaust manifold and riser?
chicagozalewski
Groupie Joined: October-29-2012 Location: Chicago Status: Offline Points: 40 |
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
nautique frk
Platinum Member Joined: February-16-2004 Location: United States Status: Offline Points: 1784 |
Vince.... 803-345-0996
nautique frk
Call Vince at Skidim.com he may can help you.
chicagozalewski
PCM 351W GT40 310MPI (2001 SAN210) V-drive
still looking for the damper plate 15 spline new at a good price or used in good condition cheapest I found for $ 160.00 (new) has anyone a better deal? Is there a cheaper replacement? |
phatsat67
Call me Monday? I think I have a stock flywheel I will have to check fitment.
We use a company for the injector rebuilds. I have kits in stock to rebuild the Sherwood pumps. 317-845-9253 open at 8am. Most everything else can probably be repaired. |
chicagozalewski
the injectors from the Ford Mustang Cobra 24 lbs will fit?
Towbosssupreme
Senior Member Joined: August-28-2009 Location: Mullins S.C. Status: Offline Points: 102 |
1. Exhaust manifold, outlet riser
2. Flywheel 3. Starter 4. Alternator 5. Fuel injectors 6. Water pump Sandblast, prime and paint (1) (2)/// Hand sand prime and paint , rebuild (6) /// send off to a rebuilder (3) (4) /// Go to Napa (5) |
Tow Boss Supreme 71 Separator(sold) 70 Barracuda ,80 S.N ,88 Barefoot Nautique 78 American Skier 78 Martinique 77 Fish.N 67 Skylark 69 Baracuda 70 S.N. 73 Mustang,65 Century Coronado H.T 70 Century Corona
Towbosssupreme
2. Flywheel 3. Starter 4. Alternator 5. Fuel injectors 6. Water pump Sandblast, prime and paint (1) (2)/// Hand sand prime and paint rebuild (6) /// send off to a rebuilder (3) (4) /// Go to Napa (5) |
Towbosssupreme
Thanks(1)
2. Flywheel 3. Starter 4. Alternator 5. Fuel injectors 6. Water pump Sandblast, prime and paint (1) (2)/// Hand sand prime and paint (6) /// send off to a rebuilder (3) (4) /// Go to Napa (5) |
chicagozalewski
PCM 351W GT40 310MPI (2001 SAN210) V-drive, fresh water system cooling
I'm looking for engine parts, new at a good price or used in good condition. damper plate PCM 15 spline phone 708-408-9619 Piotr 1. Exhaust manifold, outlet riser - made sandblasting 2. Flywheel - I bought 3. Starter - I bought 4. Alternator - I bought 5. Fuel njectors - I bought 6. Water pump - I rebuild |
