  New Posts New Posts RSS Feed - MOTOR temp?
MOTOR temp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: MOTOR temp?
    Posted: December-08-2012 at 3:24pm
Linda,
The infrared temp gauges are real cheap. You can purchase one at Harbor Freight.
Clean up all your wire connections from the sender to the gauge as well as the supply to the gauge and see if that helps.
The only other issue may be the PO pulled the T stat out thinking he had a cooling problem.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 12:59pm
Originally posted by eljayrx eljayrx wrote:
Originally posted by skicat2001 skicat2001 wrote:
150-160
what? on a WRC? never go that high.. are you sure buddy?The most for me is 130 tops
You had better "shoot" the engine with a infrared temp sender next to the gauge sender. You may have extra resistance in the wiring that is causing a low temp reading on your dash gauge.
ok .. who can do that? Marina?... ty---------- Will get on that asap in the Spring..
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 12:34pm
i agree with Pete - Also
Is there a themastat installed ???
If not it will never warm up.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 11:54am
150-160
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 11:24am
150-160
Too add to that,is RWC raw water cooler right. That temp I dont know just the standard temp.
1985 CC 2001-SOLD
Lee Michael Johnson
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 11:23am
150-160
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 11:20am
150-160
1985 CC 2001-SOLD
Lee Michael Johnson
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2012 at 11:14am
RWC--------------------is 115 to 135 right?
