  New Posts New Posts RSS Feed - Alignment Poll
Alignment Poll
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Topic: Alignment Poll
    Posted: January-14-2013 at 10:47pm
Originally posted by skicat skicat wrote:
Originally posted by BuffaloBFN BuffaloBFN wrote:
I only check mine when I pull the engine.
So you do yours annually?
Just kidding man!
For a while I was seeing annually go by pretty quickly! It doesn't need to come out this year, but I could do it for a ceremony of some twisted kind.
I'm looking forward to burning some gas with yall this year. That part I have figured out.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 9:15pm
Originally posted by MI-nick MI-nick wrote:
pete, i meant that i unbolted and checked alignment with feeler gauges between coupling halves...i'm not as dumb as i look...
I got it now. Sorry for the misunderstanding.
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 3:06pm
As far as I can tell, I'm not quite sure...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 8:29pm
i aligned my '88 after having the transmission rebuilt about 3 or 4 years ago. checked it last summer (unbolted coupling) and it hadn't changed. i'll probably continue to check every other year.
on my '99 SAN i have only done the prop spin check because...well...the coupling is a PITA to get to...spins by hand real easy though...
Nick,
Unbolting the coupling is not needed for a prop spin check. In fact, you do not want to unbolt it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 8:27pm
Originally posted by Waternut Waternut wrote:
when the boat goes in the water, wouldn't the hull always goes back to it's original location? If it doesn't, wouldn't something be severely damaged which prevents the hull from going back to it's natural state?
I really couldn't say if a hull goes back to it's as built original state. The poly absorbs water easy but it does dry out easy. Considering that, an alignment check is important within the first 25 hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 3:17pm
Waternut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2013 at 11:40am
I definitely understand polyester resin can absorb water and I also understand that some boats have wood stringers. I even understand that a boat flexes differently when on the trailer and in the water. However, when the boat goes in the water, wouldn't the hull always goes back to it's original location? If it doesn't, wouldn't something be severely damaged which prevents the hull from going back to it's natural state?
MattB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattB Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2013 at 7:15am
I replaced the shaft at the end of last season and the boat has probably had about 10hrs (guess) with the new shaft so as part of my spring service I will be checking the alignment before I head into another full season, if there is no alignment problem it will probably take 10-15 minutes to quickly check so its no big deal and peace of mind for very little effort.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2013 at 9:10pm
I don't understand how such a stout series of components works it's way out of alignment.
John,
You may want to use a different word than "stout"!! Alignment will change from the boat on the trailer to the boat in the water. It's the reason Eric likes to do engine alignments in the water. He's stated it several times that it always surprises him how much it does change.
The biggest issue affecting alignment is water absorption both in wood stringers and polyester resin. You do realize poly resin is hygroscopic correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2013 at 7:28pm
I'm more curious to know who has actually loosened the couplers, rechecked alignment, and found it to be bad... I have a hard time believing that a properly aligned driveline will lose alignment without hitting something or an engine mount loosening up.
I totally understand the importance but I don't understand how such a stout series of components works it's way out of alignment. I've seen rubber components wear to fix a problem with the physical alignment of the metal joints but not the other way around.
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 5:21pm
In my opinion a good portion of the enjoyment of owning an old classic boat is the time you spend relaxing while polishing, waxing, and maintaining it. Just as recreational oil changing seems to be a gearhead pastime I would venture a guess that there are recreational aligners. Being an incurable OC, I will probably join their ranks.
On a cold winter day there are few things as satisfying as going to a warm garage, liquid refreshment in your hand, music playing in the background, and the familiar aroma of a boat bilge. Some of the most enjoyable times of my life with family and friends flood back whenever I experience it. Boat maintenance is therapeutic. I feel truly fortunate to have an opportunity to enjoy these things.
Sorry for the thread jack, but I am feeling really lucky to be a part of the CCF family today and want all to know how much I appreciate all of the help and advice I have received from so many of you. THANX.
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late!
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 4:03pm
Just kidding man!
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 9:39am
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 5:53am
Originally posted by Tide Tide wrote:
I've owned my boat for over 12 years and have never done an alignment.
Ditto
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 2:28am
Chris,
I only had to adjust the 89 once when I first got it. When I checked it almost annually nothing had changed still within .003 limit. Always considered that was an indication that my stringers were fine. With the large surface area under the engine cradle it would take quite a bit of rot to have an effect though.
The 98 Sport was spot on when I checked it straight after it arrived in Australia. The prop took quite a few hits last season. When I did some prop reshaping after these hits. I used Joe's method of checking the ease of turning the prop shaft as a indication the prop shaft was not bent or the alignment had changed. Checked it at the start of this season still spot on.
We are into the last few days of our vacation at Whistler BC. Sad the holiday is ending but it will be nice to get back to some sunshine and boating in Australia.
89 Ski
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 1:21am
Originally posted by lewy2001 lewy2001 wrote:
Check mine every 100 hrs when I also replace the transmission fluid.
Lewy - How often do you have to adjust it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2013 at 1:18am
Originally posted by tbeard tbeard wrote:
Is there anything else I need to consider prior to assembly?
If the cutlass bearing has not been replaced in the last couple of years, now is the time to do that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: January-01-2013 at 10:13pm
89 Ski
tbeard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbeard Quote  Post ReplyReply Direct Link To This Post Posted: January-01-2013 at 9:23pm
Great timing on this topic. We just finished painting the bilge and ready to install the engine. I did not remove the shaft from the boat. Watching Pete's video I am thinking I should loosen all 4 engine mounts and make sure they move freely before installation. I am positive I will have to tweak the engine to meet/exceed the .003 max spec requirements. Is there anything else I need to consider prior to assembly?
Thanks.......Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2012 at 12:30pm
I know the last time I checked mine was after Eric rebuilt the tranny which was about 4 years ago I think. I haven't checked it since then but I do throughout the year grab the prop to see how freely it spins (usually everytime we stop for break and play in the water I'll dive under and check it). I think y'all have brought up a good point as we've all heard/read the stories of misaligned shafts and guys here injured because of it. Probably not a bad idea to check it before the first outing of 2013. I'm glad you guys brought it up.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2012 at 12:28pm
Owning a boat, even a classic inboard is not rocket science and doesn’t require one to own a set of feeler gauges or to have a mechanic on speed dial ..
Personally I do what is recommended in the owners manual which is
“Periodically check alignment by visually inspecting and turning the prop to assure yourself that it turns freely with no binding”
I suspect that for most people doing more than that on a boat that hasn’t recently hit something is far more likely to cause harm than good.   Even if it has hit something a good spin by hand has always told me whether it was limited to the prop or if the problem went deeper.
A couple spins of the prop by hand on a boat I am looking at to buy tells the same tale, if it is loose in the strut or binds at one or more points while turning around I am deducting the cost of the parts from the bell housing back from my offer…
For the poll - I aligned my 83 when I put in the new stringers, transmission, and mounts five years ago.. I have had the engine out a few times since then, and even switched blocks but haven’t removed or adjusted the trans, bell housing, or the engine mounts.. each time I bolted up the new engine then gave the propeller a spin and decided not to touch it so that is one actual alignment in 5 years. But I give it a good spin every chance I get (10+ times a year)
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2012 at 11:19am
And there we have it, Pet owes everyone an apology. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2012 at 10:28am
Well I wondered where I got the idea that it had to be checked annually, so I looked at the owners manual - it just says to spin the prop to check for binding. I then found this old post from Eric suggesting annual alignment:
Posted: March-19-2007 at 12:15pm
perfect scenario is to check it in the water if you can, these boats are very short and rigid and you can get by on the trailer, its the 25 footers and up that should always be checked in the water, any time you strike an object it is a goood idea to check the alignment, i would add it to the spring list of checking it once a year. boats with rotted stringers should be checked more often if that problem is not fixed. if you do decide to check it in the water at least let it sit overnight or longer to let the boat settle to its natural state.
Alignment is often overlooked and is as important as checking the oil, I dont try to advertise this to much because, well you know...
but alot of transmissions i see are failed due to mis-alignment and it causes hard part damage, vibrations, excess heat and so on
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2012 at 8:52am
Originally posted by DHart DHart wrote:
I go for every 2 years. 2 of my 3 boats were done 2 seasons ago.
Pete, what do you typically find when you check alignment? Do you make adjustments or just confirm that everything looks good?
Dave,
It really depends on the boat. A glass hull with good stringers or a recent stringer replacement rarely has issues except when it taken a underwater hit.
With a wood hull, you will typically find different readings after it's dried out from storage compared to later in the season when it's taken on some moisture. Check the alignment later in the season.
If you find that the alignment is out past the .003" max, do a complete alignment.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 11:56pm
Ha last time mine was checked you did it to make the alignment video Pete.
DHart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHart Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 11:42pm
I should have included, I'm in the rarely check alignment club.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 11:34pm
I've never used an alignment pole.
I just use a worn out prop shaft to tune (bend or un-bend) the strut and to nudge the engine side to side.
Oh! Poll! with two el's,   Ok, well other than changing engines, velvet-d's, ARE's etc...
As a part of routine or preventative maintenance.
1966 Mustang    (never)
1974 Ski Nau.   (once, in 8 years)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHart Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 11:03pm
juniorwoody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 10:47pm
Is anyone keeping count? Both of our woodies are apart at this time. The
Atom probably should be checked before the season though I hadn't really planned to do it till now. My son's SN was aligned three seasons back when we completed the stringer replacement. It is working fine and I hear no plans for the alignment check. I guess if his tranny goes he will just fix it as that is what he does for a living. Ya, ya I know an ounce of prevention is worth a pound of cure and all that stuff. My comments on the Craigslist thread were more centered around how we receive new posters and should we try to maintain a small amount of decency or just go about alienating them before they even get started, just saying.
The value of money spent on new adventure far exceeds the value of money saved for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2012 at 10:47pm
I've owned my boat for over 12 years and have never done an alignment. It has absolutely no vibration.
From several posts above:
Originally posted by TX Foilhead TX Foilhead wrote:
I haven't noticed vibrations.
Don,
Keep in mind that a misaligned shaft will not vibrate unless it's been run that way for many hours. With a misaligned shaft, it is binding in most cases the cutlass. Without any clearance/play it will not vibrate until the cutlass is very worn.
The most common cause of vibration is #1 a bad prop and then #2 a bent prop shaft.
