'73 Mustang |
Post Reply | Page 123> |
Author | ||||
Tonali_III
Senior Member Joined: August-30-2004 Location: St. Louis, MO Status: Offline Points: 412 |
Posted: January-19-2013 at 6:40pm |
This just in: according to Art Cozier at CC Orlando, my Mustang was originally equipped with a Chrysler 273cid (just as we all suspected). The boat was "completed" December 1971, making it a 1972 model. Hence the short VIN number (M3214) as opposed to the standard 12 or 17 digit variety started in 1973.
Also, there is a possibility that this engine may have been changed by an engine rebuilder sometime in the 80's. The boat was purchased new and donated to the Moody Church of Chicago, Illinois for use at a youth camp in Wisconsin. The boat was originally purchased from Watercraft Sales in Three Lakes, Wisconsin from John Lamon, Sr (probably while Pete was working there). The boat developed an engine problem (described as a "knock" in the engine) and was returned to the donor in about 1997 or 1998. The boat was placed in a garage at this time where it has been ever since. |
1974 Southwind 20
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6752" rel="nofollow">1972 Mustan |
Based on the details of the "restoration", combined with the fresh paint on the engine and non-original exhaust manifolds, I would certainly be taking everything that seller says with a grain of salt. The casting number on his engine would be a clue as to whats in there now, but the only definitive evidence would be in CC's factory records. |
Tonali_III
I knew you worked for John, Sr, so I know that you would know for certain. I will definitely check when I get up there in 2 weeks. You going to be around there the weekend of the 26th, Pete? I am thinking the engine may have been replaced, but I will check. Thanks, Tony |
1974 Southwind 20
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1424 |
This one may be of interest 69 SS Mustang Ask him if the engine is original to the boat, its worded as if it is.
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
I just havent seen an original boat so equipped Bruce... which leads me to believe that CC simply didnt offer the 318 as an option in the 16' hulls. Maybe they thought they would overpower the boat? Not sure. Same reason they didnt offer 340's or 351w's... 302/305/307/273 seem to have been the offerings in that hull.
318's were common in the larger Barracuda, SN, etc. |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7957 |
I don't know much about Chryslers, but did look at a pair of engines recently for a friend and one did still have a tag on it and both did have the displacement cast into the port side.
Why are you guys so sure a 318 wouldn't have been originally in that boat? A 273 may have been more common, but is it really unlikely Correct Craft would have put a 318 in a Mustang? |
Not sure Chrysler put tags on the engine? Decals (if exhaust manifolds were reused and not painted over) would be the best clue if the block could have been replaced. Arts records if they're missing.
Chrysler DID cast the displacement into the block. It's down low on the port side iirc. No need to look anything up- it's easy to tell what's in the boat now. From a few feet away you can't tell the difference 273/318/340 though. |
Tony, You can't tell the two displacements apart from looking at the engine. You need to go to the engine tag and look at the engine model # and then, go to Hurrikain ID your engine. I worked for John Sr. and trust me, unless he had the paper work in front of him, he would not be able to tell the difference ether. At least the PO didn't tell you the boat came from Cypress Gardens!! Look at the engine tag!!!!! |
Tonali_III
I am going by what the owner John Elsen. He claims he bought it brand new from John, Sr. at Watercraft Sales.
I plan on checking for certain. It doesn't matter, really. It's going back together with what it had from Orlando after I get her home. |
1974 Southwind 20
Tony, How did you determine it has the 318? I'm with Tim on this and the 273 would be the common engine for a Mustang. |
Tonali_III
I agree, Tim. Unfortunately, I have no pics, yet. I am even thinking this could have some sort of Ford variant in it that the present owner is mistaking it for.
I will know more in a couple of weeks. |
1974 Southwind 20
It may very well have a 318 in there now (it will be cast into the block) but that doesnt mean its original. 318's would have been cheaper and easier to find if the block was ever replaced. Art's records would be definitive, but if you have any pictures of the engine, those would tell a lot.
Tonali_III
Tim,
The owner seems pretty emphatic. I will find out when I hear back from Art and when I pick her up in a couple of weeks. |
1974 Southwind 20
If no wet foam, youre looking at just over 2k lbs dry weight (1600 boat, 450 trailer). Even with wet foam and fluids, you're probably still only in the 2500 range.
Id be very surprised if that boat came with a 318. Does it have any of the original stickers on the exhaust manifolds or valve covers to indicate which model it was? The 200hp was a 273. |
Tonali_III
I talked to the owner on Friday and closed the deal for the Mustang. I am planning on picking her up the weekend of Jan 26-27.
It definitely has a LM318 in her, so I am checking with Art Cozier at CC Orlando to see if it is the original engine. What kind of towing weight am I looking at? Can this be towed with a Ford Ranger with a four banger? How about a Jeep Cherokee with a V6 (as opposed to their reliable 4.0L I-6)? Or am I looking at towing this with my full sized F150 with my 300cid, L6? (strong as all get out and will pull stumps, hmmm wonder why it was never put to marine use?) |
1974 Southwind 20
He told me the same too,well we don't need them yet anyway
62 wood
Hey, Gary,
you didnt get "my" tach back yet, did you? |
62 wood
Slow? he told me, my tach would be at least 3 or 4 weeks... ..... he aint never lied! Tony, Dale is who has my tach... |
Tonali_III
Sounds good to me, Pete. That way I can keep it original. |
1974 Southwind 20
Tony, Dale is a ACBS member and belongs to one of the chapters I do (Glacier Lakes). His business is fairly new but he's be around the insides of gauges for many years. I know many ACBS members who have used him and can say I have heard nothing but good things about him. He's a wood boat owner so he knows what it takes to do an original restoration. |
Pete recommended him Tony,seems like a nice guy. He is storing several members gauges right now
Tonali_III
I heard back from Dale, Gary: Hi Tony, Please call me regarding your speedo. Dont let that Mustang get away. Thats one nice boat in any condition Thanks Dale Kocian Kocian Instruments (920) 336-1591 looking forward to picking her up in a couple weeks. |
1974 Southwind 20
Tonali_III
Thanks for the link, Gary. I sent them an email and will let you know what they say.
Thanks again. |
1974 Southwind 20
Tonali_III
WOW!!!
Those are gorgeous, Gary! Now I will have to keep on the lookout for a nice set. Steve mentioned a place that puts AutoMeter guts in Teleflex housings to make them work correctly. |
1974 Southwind 20
Thats a good deal on the horn Tony,I paid way more 3 years ago. The gauge
thing is tough,they are not made to be taken apart,the bezels being crimped on.I had nothing to start with and lucked out finding these on ebay.The lens were clean and the chrome rings polished up nice. Teleflex's were/are on the low end and some gauge repair guy's don't like to work on them. After 2 years of looking I finally found an hour meter! You could check here with Dale to see what he thinks. Gauge repair when sent out is expensive and slow. here |
Tonali_III
I suspect that I will need to restore the gauges. I have never taken apart any of these old Teleflex gauges for restoration.
Are there any tricks in cleaning and restoring the faces, bezels or internals? Pete, I would think you may have some good experience with this. |
1974 Southwind 20
Tonali_III
1974 Southwind 20
Tonali_III
Gary, I could only find these at Freeport Marine. There is an eBay store that has them but the price difference is only a couple of bucks. Tony |
1974 Southwind 20
Tonali_III
Thanks, Gary. I am picking it up for a "reasonable' price. (Translation: I did not pay the asking price.) The worst that could happen is I have to part her out. But I got this stubborn streak. I like to make silk purses. Being a '73, I take it this is a "foam" boat? Tony |
1974 Southwind 20
Tonali_III
I see the angle. Kind of makes you go "Hmmm". I take it the Mustang has 4 stringers in the floor? |
1974 Southwind 20
