Airguide Speedometer Conversion to GPS |
Post Reply | Page 123 4> |
Author | ||
winniskier
Senior Member Joined: March-15-2008 Location: Gilford, NH Status: Offline Points: 193 |
Posted: March-30-2017 at 9:56pm |
Meanwhile back at the ranch, I've been given the chance to buy a never-used 2010 Precision Star GPS Speedometer rather than undertake a conversion. Perfect Pass says that the original 2010 speedometers updated 1 time per second, (1 Hz), the new ones have a 5 Hz GPS, and the 2010 model should work well, just has a slower refresh speed when accelerating. Is this a model T or last year's model? Do you think there will be a meaningful difference?
Jim
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
If Henry Ford stopped in and was soliciting feedback on how to improve his prototype before putting it into production, then I'd say you missed the boat Pete.
You're not going to re-engineer this GPS conversion kit at this point in order to gain 3mph worth of travel. That feedback was already presented, and the design was finalized in 2013. There are other options to work around this limitation that I mentioned. Your argumentativeness is not exactly helpful. |
I'm glad to hear your model T is still running well Yup, design considerations never come to play after development since they are "set in stone". |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
That's pretty clear, Tim. Oh well. First thing to go....well....maybe second.
Happy to talk about the speedo all you want, but it is too late to influence the design considerations as that was set in stone many years ago. Geez you need some reading comprehension help sometimes Pete! |
LaurelLakeSkier
Senior Member Joined: February-12-2007 Location: Wisconsin Status: Offline Points: 485 |
The world is full of youth—what we need is a fountain of smart!
Yes, let's just forget about all the new members who have come on since the old post! |
This thread is 3 years old, not a relevant discussion as the product is already out there.
If you need to read the upper 40's and higher with accuracy, you can go to a 60mph, 80mph or a custom face with a custom scale if you want... the GPS gauge can be calibrated to any scale you'd like. I am running a custom 80mph scale on my BFN... reads accurately into the 60's. |
tryathlete
My take is that there's nobody concerned with speeds below 10, but there are quite a few boat owners who travel just below or very close to 50 (my SS will hit 48). I'd rather be able to read high end then hit the post on the low end. |
Orlando76
If you ski I couldn't imagine not having Perfect Pass. I was hesitant for the longest time until I started skiing other boats with PP/ZO.
You lose the Nautique face on the internal receiver- it comes with a generic one (presumably pre-calibrated). I and several others have run the external receiver version for a while, they work great. Smooth, reliable and great customer service from NauticLaugic. I added a 2nd one this winter.
winniskier
I am considering a speedometer conversion to GPS as I am too cheap to jump all the way to a Perfect Pass.
Please send current thoughts about an Nautic Logic upgrade. I prefer an internal GPS receiver. Nautic Logic claims that the internal and external receivers have the same excellent reception. Do you agree? |
Jim
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Wet-N-Frugal
Newbie Joined: February-23-2013 Location: WA Status: Offline Points: 1 |
More info on the GPS upgrade:
You can see the 'fluidity' of the needle movement on this you-tube video. The video walks thru the Calibration Procedure. For a 5 to 50 MPH gauge, Cal points are sampled starting at 10 MPH, upward every 5 MPH, the last point at 45 (Full Scale minus 5 MPH). The result is an accurate speed report across the full 50 MPH. http://youtu.be/SwXAfIttEQM |
-WNF
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
My 1980 came with the Electronic Speedo, but I replaced it with an Water Pressure Air Guide. I am thinking that 1980 was the only year that this was offered . Very Cool Stuff. Donald |
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
So how much are you selling the DIY kit for?
"I don't know what the world may need, but a V8 engine's a good start for me"
ClassicBoatwork
Senior Member Joined: July-19-2008 Location: United States Status: Offline Points: 119 |
nautic Laugic did a pretty good video on the installation process.
I cringe when he tells you to cut off the nipple on the diaphragm though!! I have never seen that plastic frame before. Video Dean |
ClassicBoatwork
Now that is the right kind of thinking! Someone told me the Electro Marine was used for only three years. Paddle wheel? |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Online Points: 6156 |
HW is right on. Wasn't there a set of those on ebay a few weeks ago?
That GPS is tempting. I would like to fill in all the pitot holes on my transom and never have to worry again. |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
It looks like the optional electronic speedo from around 1980.
Air206
The flush mount pictured is a "fancy" Electro-Speedo....... not a typical flush mount pitot-driven Airguide which has a dial that is calibrated to 50 MPH. |
bhectus
Platinum Member Joined: July-04-2010 Location: Gator Country! Status: Offline Points: 1809 |
The sweep on the flush-mount only goes to 40mph? I thought it was going to go to at least 47?
'87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001 |
ClassicBoatwork
I have finished my first pair of GPS retro-fits.
I took the pair out this morning in our car and they track together great. |
ClassicBoatwork
I think I see my errant ways... I added the quotes to my link and your software does that automatically.
ClassicBoatwork
Thank you!
Hollywood
Dean, go ahead and quote Larry's post above, you'll see where everything fits.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6124 |
Yeah...still needs a little work Here you go. Air Guide Service Air Guide to GPS info Inquiry Form |
ClassicBoatwork
arg.. I don't understand these links I guess...
http://www.classicboatwork.com/classicparts/gauges/airguide/agr/agr.html http://www.classicboatwork.com/classicparts/gauges/airguide/gps/gpsretro.html http://www.classicboatwork.com/form/gpsform.html Sorry about that... Dean |
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
you link just takes us to this thread.
Proud 1968 mustang owner and now
1970 Mustang |
ClassicBoatwork
