  New Posts New Posts RSS Feed - Mercruiser carb adjustment
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Mercruiser carb adjustment
    Posted: January-19-2006 at 6:39am
Well diffently start with the timing. Adjustments to the carb are meaningless otherwise. Check the plugs, cap and rotor first and make sure they are in good order, then set the timing, then go to the carb.
henkjvr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote henkjvr Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2006 at 4:29am
My friend has a 1983 S/N with a Mercruiser 198 (5L) engine.
The engine sounds very rough and is under powered. I am not sure if it is a timing or carb setting problem. Where can I start to look for faults and is there perhaps a carb diagram (with location and standard settings) for the particular engine / carb.
SN1990-Yellow
