  New Posts New Posts RSS Feed - Electrical Issue?
Electrical Issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Electrical Issue?
    Posted: April-09-2013 at 8:25pm
This is where a VOM (volt Ohm meter) sure would be handy. Dirty battery connections would be my first suggestion as others have mentioned. Then the ignition switch and then the start relay (solenoid). When you clean the battery posts and the cable connections, make sure you use one of the wire brush type terminal cleaners designed for the job.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 7:40pm
Ignition switch going bad?
1987 Ski Nautique
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 6:13pm
Originally posted by td_in_nc td_in_nc wrote:
Just want to clariffy that the last time it occurred none ot the gauges worked. I had been turining it over numerous times that day with nonissues. I don't recall if this was the case on the prevoius times the problem occurred.
Yup, this adds weight to the suggestions of cleaning and tightening all posts and connections.
I think it theoretically possible for a bad battery to have internal problems that will give intermittent no power condition. That would be something to question if you're getting no power all the way up the chain when chasing down this problem.
td_in_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 6:00pm
forvicjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 4:46pm
Originally posted by davidg davidg wrote:
I had similar issues last year. Turned out my starter was shot. Got the starter rebuilt and no further issues.
Only thing about that is you would have power elsewhere. He is losing power everywhere to my understanding.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 4:30pm
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 1:27pm
Originally posted by forvicjr forvicjr wrote:
I would take it out make it repeat the issue and have a test light on hand and check for power coming out of the ignition switch. Sounds like a ignition switch issue to me.
Agreed, but clean your connections first "Clean + Tight", (dont forget I.switch, selenoid, etc) its easy and free.
Then take test light out with you. If it happens again start checking for the other issues stated above.
Keep us posted!
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 12:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 11:59am
I agree with Steve... Ive had this happen many times on many different boats and 95% of the time, its due to a bad connection on the battery cables. Check the battery end, relay ends, starter end, and block ground.
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 11:05am
Sounds like your starter relay is going bad. My '87 BFN exhibited the same exact issues when I first got it. New starter relay fixed the problem, but check your batt connections first as mentioned. That's a free fix.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 1:23am
It could be a bad breaker too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 12:54am
Thanks - I will clean all of the connections and see what happens. It only happened 3 or 4 times last summer and I used the boat for over 100 hours. And when it happened it would only be once and then run fine after that. I had completely forgot about it until it did this past weekend.
cphase View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 12:16am
Get out your VOM and use the diagram below to make sure you are getting voltage.
Thanks,
Jeff
82 SN
Arch Linux
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2013 at 12:06am
I agree with double checking all the connections. Cleaning and tightening.
On the neutral safety switch, this just interrupts voltage to the starter motor. All of your other dashboard electrics would still work normal if it is just a bad neutral safety switch. You said the voltage gauge shows nothing either, when it's acting up, so that kind of rules out the NSS.
I would double check connections around the key switch too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2013 at 11:59pm
Try cleaning your battery connections, both terminals at the battery , ground on the block and the Pos. on the starter.
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2013 at 11:46pm
I have a very sporadic problem, where my 1985 SN 2001, will act as if the battery is completely dead. I will be running the boat, then when I shut off the engine to pick up the skier, I try to restart and it acts as if the battery is completely dead, I move the throttle to make sure I am in neutral, and I just keep bumping the key then all all the sudden it turns over. This past weekend while I was working on the boat this occurred and I noticed the the battery gauge showed no voltage, then I turned the key again and gauge showed power and turned over (I did not even move the throttle). This is very sporadic, so I cannot predict when it will happen or check any thing. I am thinking it may be something to do with the neutral safety switch, but wanted to see if anyone had a suggestion.
Thanks
Tom
