  New Posts New Posts RSS Feed - 70's 302 RR Distributor
JDD33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Topic: 70's 302 RR Distributor
    Posted: April-16-2013 at 7:53pm
Thanks Art, we are all good and all of our friend s and family that were in the area for the marathon have checked in and are safe.
It's a shame what this person or people did we do live in the land of the free .... It's not fun having to think twice about taking your family to a large social event then worry if your going to get injured or killed. I will not live in fear.
Old school goin back to school!
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 1:08pm
JD..... Thanks for the kind words; I'm always happy to hand out information if I am sure of what I say.
I certainly hope you didn't suffer any personal tragedies in Boston. Bad enough, the d*** terrorists are ruining everything.!
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 1:50am
Thanks all!
Just to clarify , in my ignorance I did not know that a Standard rotation and a Reverse rotation distributor spun in the SAME rotation! God only knows why I would of thought that a left or right rotation engine would spin the dizzy in the same direction? Because I know my engine is a reverse rotation engine and the firing order is reversed and I needed to buy a reverse rotation dizzy in my thought process that would mean that the whole dist was reversed!!
That said, I don't know everything, but I can hold my own.... I don't post here to be made fun of, I'm just trying to learn as much as I can.
I didn't see the little arrows in the diagram showing the dist rotation till after TRBs comment, and it all became perfectly clear after he said that both dizzys spin counter clock wise. Now I know.
Art,
Thanks for the insight on the gears, I pulled the dizzy this am and swapped the gears from one to the other and you were right.... At first fitting the holes weren't aligned and I was PO, but I took a minute looked and spun the gear and all lined up.
With all that going on in Boston today and with friends running the marathon the project took a back seat for the rest of the day, I'll start fresh tomorrow. Thanks, John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 10:24pm
Originally posted by ArtCozier ArtCozier wrote:
Now, to some obstacles you might run into swapping the gears: Sometimes the hole for the pin is not drilled truly on center. If you look in the hole and see that the gear and the shaft don't line up well, turn the gear 180 degrees on the shaft and check again. I have broken gears trying to push a pin into a misaligned one. Art
This is why they make things called a "reamer".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 10:21pm
Confirming what has been already stated, distributors turn the same direction regardless of engine rotation. Did someone actually tell you you needed a RR dizzy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 1:37pm
Just now noticed that you have a '70s engine. The OEM dist could be a Mallory. Does it have a conventional cap with the wires coming out of the top, or does it have the wires coming out of both opposite sides? We called it a "crab cap" because it kind of looks like the legs of a crab.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 1:29pm
TRB is correct; that is why we have to have the reverse-cut gear and cam. It makes the dist turn the same way even though the cam is turning the opposite way. The RR cam also has the gear teeth cut opposite. That's always a handy way to tell whether any Ford engine with front distributor has the correct rotation starter on it. Someone has a no-start and just changed out a starter motor, first thing to do is open up the dist and see which way it turns. All front-dist Fords turn CCW as viewed from above, just as TR said. The reason for this is so that the axial thrust force "end-to end" thrust always has to be downward, because that is where the block is designed to absorb the thrust.
Since you will be going from a Presto to a Mall dist, check the height from the bottom of the gear to the hole. Sometimes it's different, and that presents a whole set of new hassles.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 1:05am
Alright!!!
Thanks Tim! I'll tear em apart tomorrow and swap the gears! John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 12:22am
Like i said, nothing rotation specific about the dizzy except for the gear. RH and LH distributors spin the same direction (counter clockwise as viewed from above). I've performed the swap described above several times. It takes 2 minutes to pop out the roll pin and swap gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2013 at 12:09am
Thanks all for the input,
Art, I was trying to keep it close to original but will strongly consider the electronic as an option.
Tim, the mallory I bought is a marine mech advance , so if I were to change the gear and the rotation then wouldn't the dizzy no longer have that degree of advance? The spring loaded plate would be spinning backwards. Thanks, John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 11:33pm
There's nothing rotation specific about the dizzy besides the gear. You can likely swap the gear over from your old dist, assuming it is also a Mallory. Just verify that the shaft diameter is the same. You can buy a new gear for ~$30 if they won't swap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 11:26pm
Last I heard, you can still get a dist with a right-hand rotation gear on it from Mallory. It will be an electronic distributor, but unless you want a points-and-condenser type for originality, you will find the electronic one to be more dependable. You have to get someone at Mallory on the phone that understands about reverse rotation Fords. I would ask to talk to the oldest guy there!
I know for sure that there are no Ford right-hand gears or distributors available from PCM. I would think that some marine engine conversion company would have them; there are still a lot of RH engines out there in big boats as well as in Correct Crafts.
Art
"Art"
ST79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ST79 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 7:32pm
I had the same problem do you have the old dist? If so you can take the Mallory gear off and put the old gear off the old dist. and it will work . I suggest to let some one that knows how do it because the gear breaks easy. I know it works because I had it done a month ago. If you need a dist. I also have one.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2013 at 7:19pm
Ok my grand plan to get the mustang back to safe marine component status just went up in smoke
The mallory marine distributor I bought used is a left hand rotation !!!
Does anyone have a points style reverse rotation distributor for a ford 302 they would like to sell?
Or any suggestions as to where to look? My searches even in the new part market has not been successful for the RR ford.
Thanks, I'm quitting for the day and gonna go have a beer.....
