water pump... |
Posted: April-29-2013 at 7:31am |
That would be the shaft seal so run it as mentioned and see what happens. Did you have full garden hose pressure turned on? How did you have the hose hooked up? If you have see any of the threads about running you engine on the hose, the plumbing is open to the through hull pickup see excess water will run out it. The RWP will only suck what is needed. IE: the RWP doesn't see full pressure. |
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
Seemed to be a drip coming from the slot in shaft when not running hooked up to hose.
Andrew,
Did you notice where the water was coming from? The shaft seal, the cover or a hose? Get it in the lake and try it. I have seen seals dry up over lay ups but then some running and they seal up. |
AAM196
I just pulled the boat out of winterstorage and everything fired up as expected. I ran it to temp no issues and shut down. I then noticed water dripping from waterpump... slowly... but still dripping. I started the boat back up and it stopped driping, it sounded great running as well. New impeller etc. Temp never exceeds 158-160. Do I need to rebuild /replace pump soon or is this just because I hooked hose up and am forcing water through engine rather than using fake-lake?
