Ultrasonic cleaner solution recommendations |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Posted: April-30-2013 at 9:35pm |
Tom - in addition to being impatient the Simple Green Purple (Pro-HD) is designed to work in ultrasonic cleaners (thats what it says on the bottle) and is safe for all metals.
I read somewhere that high Acid or Base content ("or" being inclusive here, meaning either one will) is what causes the etching. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3363 |
When we bring our carbs into the lab for ultrasonics,
Found that Lestoil and water is the shizzy. I cuncur, Standard simple green is really an aweful degreaser. Havn't used it yet, but suspect the HD could be more like Oil Eater, Castrol Super Clean or Zep Industrial Purple? Some of these will etch aluminum. |
River Rat to Mole |
skutsch
One 4" x 6" x 10" piece at a time... |
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Nice!
Do you think we could fit my entire engine in that parts cleaner? |
1999 Ski Nautique 196
skutsch
Before
After Yes, that really is the same carb... |
skutsch
Ok, so being the impatient sole that I am, I was at Home Depot and saw that they carry Simple Green Professional HD - It was only $14 and some change (with tax), so I picked up a gallon.
What an improvement over the normal simple green. After only about 4 minutes in the ultra sonic cleaner, the carb went from black/brown to almost shiny aluminum. Later, I put the cylinder head in, after 10 minutes (granted the solution was pretty dirty by now), it looked better then the regular Simple Green (after an hour), not a 100% but a lot better. Don't know if I will try the expensive McMaster stuff at this point. Would recommend this stuff though, especially for carbs. I'll post some before and after pics. |
skutsch
Thanks Pete, I'll check this stuff out!
Steve,
Simple Green makes both an industrial strength as well as one designed for airplane parts. The only problem is getting it in less than a 5 gal. bucket!! Have you looked at McMaster? |
skutsch
Anyone have any recommendations for a solution to use in an ultrasonic cleaner for parts. Most are aluminum, with some brass and stainless. Generally cleaning carbs, other parts from small engines and anything off the boat or car that will fit. I have been using Simple Green, it works okay, so wondered if anyone has found something they REALLY like. Thanks!
