  New Posts New Posts RSS Feed - Craftlander Boat lift
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Topic: Craftlander Boat lift
    Posted: May-10-2013 at 2:18pm
Wayne, hope it all works out, prayers headed your way. Hopefully the guy with your deposit is understanding...
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 11:48am
Yes, best wishes from us as well, everything will be OK is my favorite thought!!
Considering what you got going on, wish Virginia was closer, I would go get your money, the lift or both.
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 12:33am
Thanks Pete, that means a lot.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2013 at 7:34pm
Wayne,
I wish your wife the best for the procedures she needs to go through. Our prayers are with her.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2013 at 11:12am
Everyone, thanks so much for your help! Bad news though, I found out this morning that my wife is going to have to have surgery, which may lead to more surgery and will require long term follow up either way. I had to let the owner of the lift know that I can't make it Virginia this weekend. I wouldn't be surprised if I lose the deposit I gave him to hold the lift.
89 SN
P71_CrownVic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 12:34pm
Ok, I measured and took pics this morning. My bunk kit is 15" from the base of the cradle to the top of the bunks. The cradle itself is around 5"-6" thick. At the front of the lift, I have just under 22" of water measuring from the foot pad of the lift to the water surface. At the back of the lift, I have just under 31" inches of water measured the same way. With the lift fully lowered I have about 6" of water above cradle.
Front depth:
Rear Depth:
As low as it will go:
Idea of how low the water is in the winter (for now):
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 11:09am
Wayne,
Go back to my UHaul post, I have moved a SS lift that exact way, everything will be in the trailer, it does end up tall but no permits required, guaranteed!! Around here the dual axle open trailer can not be rented one way and only the larger dealers have them, so I did have to pull it round trip, never have had in issue renting UHauls.
Good suggestion on purchasing new unassembled, the Shorestations do go together pretty easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2013 at 12:42am
Originally posted by dwouncmd dwouncmd wrote:
If this is the lift, and it is too wide, it appears that if you rotated it 90 degrees, it's height, less then it's width now might fit where you don't need permits. Again, this is all a guess, you would have to do actual measuring.
But as Tim (TRBenj) said, "Permits???"
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:23pm
Permits?
Wide load...
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:19pm
To add to the thread, I am hoping to pick up used Shore Station SS-36108A, so I will be going through the all of the above starting with moving it 4 hours, probably on a pontoon trailer. I have never had a Shore Station (or any other kind of lift for that matter). Is there any chance I can get away with using the elevated bunks for the 89 SN and Tique vs. the more radical solution Pete used? I probably have less than 4 feet of water at the dock when the lake is low. Is it possible to set up the bunks to accommodate the 89 SN and the 78 Tique? Is there anyone in the Triangle with Shore Station experience (or a toon trailer to loan for that matter)?
I have that exact lift and bought a bunk kit to make it SN friendly. I will measure and take pictures tomorrow of my low water example as I just got the docks and lifts in today. Our water is controlled by a dam (for now)and is lowered 3' in the winter. I'll take some pics and post them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:16pm
Permits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 10:04pm
The deal breaker for me may be the move (trailer, permits in two states?!). In some ways, it would be worth it to have new one delivered unassembled.
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 7:21pm
Lift cost is highly dependent on your location. A good used 3-4k lb manual crank lift (no canopy) fetches $1500 here in the northeast all day long. Used ones come up rarely and don't stay on the market long.
I'm very envious of the Midwest prices... Most seem to be made in wi or mn, so surely that's a huge factor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 6:31pm
Get a price on new unassembled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 6:12pm
Used free standing lifts seem to be rare down here. I have only seen a couple for less than $3000. This is the first time I have been able to get the owner to call me back. I think I can get it for around $1000. With moving and parts maybe $1500, still cheaper and more functional for my setting than any other solution I have been able to find. I guess I could look into a new one...
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 2:15pm
Those side boards and bow stop are nothing but in the way!
Ps thanks for letting me use your lift.... :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 2:11pm
That's an old lift, worth about $500 up this way. You may want to price up those parts first, if you go with Shorestation specific it can get very pricey.
This would be a perfect setup for either boat, (with or without canopy)
3800-4000 lb capacity with the more modern bunks and the slight arc in the carriage.
That pontoon trailer setup in the pic would work however you will probably be exceeding standard width regulations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 1:59pm
Measure twice rent once. I've also been left out to dry with Uhaul not having the actual trailer I reserved. Don't count on them. I made my own modern bunks with uni-strut and other misc hardware from HD. Slightly cheaper but much more labor.
Peter, I can help you this Saturday morning. Quinner will probably also be around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 1:32pm
Hollywood, I was planning to use one that supported the pontoons as pictured below, but Qinner's idea is better.
Quinner, thanks for the suggestions. The bunks are little flat things (see the picture of the less nice lift ); the lift was set up for a Carolina Skiff, so I was thinking I would buy the Shorestation kit for elevated bunks.
I will let you all know how it goes.
89 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 12:14pm
Wayne,
UHaul has an open trailer with dual axles you can rent, should be on their web site. You will need to remove all 4 feet and the wheel (canopy also if it has one), turn the lift up on one side and it will slide right in. Bring a ladder and some straps/anchor line to strap it criss cross for added stability. All the removed parts will fit in the trailer loose, so you will be good to go.
I have used the under pontoon trailer, ok for short trips, not stable enough for a 4 hr haul. Snowmobile trailer works also but prob not a whole lot of those down your way, lol.
4ft is plenty deep, if the SS is a modern bunk style you will simply need to adjust them up if not already there.
Long time Shorestation owner, they are the best vertical non floating lift out there, other then Floe if cost is not an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 11:15am
Bunks will be fine for either boat.
I hope you are using a trailer that supports the pontoons and not one that goes under the floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 8:20am
89 SN
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2013 at 12:22am
I dont really have the space or the man power. Not to mention with the 1' of mud we have in front it would be like day one every year. Im going to buy a de-icer from eBay and keep it in the water....Im trying to lobby for the other members in the cover to invest in a aerator to eventually control the mud and weeds....only time will tell
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2013 at 1:53pm
Peter, sorry, just saw this post. Sent you a PM, can help you out if you still need it.
Water is not bad, we footed on Tuesday, shorty wetsuit only.
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 8:03pm
Hey Chris and Hollywood, I'm going to try to level my Shore Station 36108 tomorrow, and set up the bunks which are loose on the cross-members. I did not even think about those fins under the Supra. Ive got to level the thing too, as it is way off. God I cannot even imagine sticking my head under water to remove the pins and to try and raise the lower corners. Boat fever means its gotta happen soon.
You guys have any suggestions on leveling? Is it mask and wetsuit and cold to the bone, or is there a better way?
This is totally new to me, just like three years ago learning to drive an inboard. Can't wait to be an expert.
2008 MasterCraft 197TT
1996 Nautique Super Sport
1988 Waterlogged Supra Mariah
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2013 at 12:04am
Originally posted by Brian82683 Brian82683 wrote:
About a foot. After some digging up front...lots of muck in the back, so I bought some 16 by 16 patio pavers from homer last night. Im gonna spend a few hours leveling and get the boat on it later today.
Awesome. Do you have to remove it in the winter time?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2013 at 10:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote P71_CrownVic Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2013 at 5:58am
I think i am getting myself all worked up over nothing...
P71 is helping. I think you will be fine.
Brilliant post. How insightful.
To the OP, glad it worked out for you. How much depth do you have to spare?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: May-01-2013 at 7:04pm
Just got to level it out tomorrow and Ill be all set! Plenty of water
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2013 at 8:27pm
Good point on the weight distribution. Nice set up you got there
