Apex motor Cranks but wont Start |
jdubb
Newbie Joined: May-16-2013 Location: United States Status: Offline Points: 3 |
Posted: May-19-2013 at 4:48pm |
The reason I over rode the safety lanyard is because of all the posts about the those switches going bad.
I have ohm out all the wires leading back to ecm and relays seems like all the wires are good. I have found that the green wire coming from the ecm is not providing power to the fuel relay. Im leaning toward ECM issue. |
JDubb
1997 Ski Nautique |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
safety lanyard comments make it suspect...maybe burned a wire regarding fuel pumps before the 50 breaker kicked?
This is the life
jdubb
I know there are a ton of these threads, because I think I have read them all but I'm at a loss.
Motor Cranks but wont start. Fuel pump does not have power. I have checked all the fuses and they all ohm out. Also they all have 12 V when the key is on (both sides). I have removed the safety lanyard and just connected the wires. I have also replaced both relays. Still no power to the pumps. If i apply 12v with a jumper I can hear both pumps run and hear fuel. However motor still wont start. What else can I check? Is this a computer issue? Boat ran perfect before I put it away for the winter. After I corrected the battery issue by purchasing a new one and resetting the breaker. THat is when the fuel issue occured. Please let me know if I can answer any more questions for you to help me solve this problem. Thanks |
JDubb
1997 Ski Nautique |
