  New Posts New Posts RSS Feed - distributer cap
distributer cap
mrfreeze001001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrfreeze001001 Quote  Post ReplyReply Direct Link To This Post Topic: distributer cap
    Posted: July-04-2013 at 12:17pm
thanks for the info got it taken care of but still wont idle below 1000 rpm.
jkilbert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkilbert Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2013 at 7:11pm
My '79 has a presto lite distributor. The cap/rotor kit that I used was a "marine" setup from the local shop. It wasn't very well made and was quite expensive. I ordered a cap/rotor from NAPA using a '79 International Scout II as my search since it uses the presto lite ignition. It was a heavier cap with no vents as was the rotor being heavier construction. The only difference I noted was the lack of a gasket in the kit. Gasket paper is cheap so I made my own. It runs like a top and it was a lot cheaper and easier to get since my local store stocks the parts.
1979 Ski Nautique
catamount View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catamount Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 11:54am
You can use whatever wires you like, but do NOT use an automotive cap! Automotive caps have vent holes. Marine caps do not. Your marine distributor should have a spark arresting screen which allows the unit to breath, instead.
1987 MC ProStar 190
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 9:39am
I got some NAPA plug wires for a 80's F150 & they were a bit too long. I trimmed several wires back & they work great.
Johnbrad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnbrad Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 8:34am
I think the plug wires are standard, but I am not sure if they are "marine" or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrfreeze001001 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2013 at 6:55pm
thx thats what ill do
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2013 at 6:19pm
Well, the thing that really makes the spark plug wires marine is their length. Takes longer wires to get around marine exhaust manifolds typically.
Check out Skidim.com, N3Boatworks.com, nautiqueparts.com, mycorrectcraftparts.com etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrfreeze001001 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2013 at 11:24am
can you use auto cap and plug wires or dose it have to be marine
