  New Posts New Posts RSS Feed - Shaft packing
Shaft packing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Shaft packing
    Posted: May-24-2013 at 8:19pm
They will drip when the shaft isn't rotating. If you don't get some water through the packing, you risk burning it up and even worse scoring the shaft.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 10:19am
According to the article Pete posted, the best adjustment indicator is temperature - 10 to 20 degrees more than the lake water is best
Mine does drip some at rest, but I only boat for several hours at a time & get no more than a pint of water (including from the skiers!)
stang7tl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang7tl Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 10:13am
I was told the when the shaft is not spinning it is to be dripless, it drips when shaft is in motion
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 9:53am
Pete - That was a good coffee read, learned some things I didn't know about, like trapped air & crevice corrosion.
Do they still sell the moldable clay? That sounded like trouble!
FYI for everyone " GTU is a knock off of Gore GFO, but it frays worse due to the braid design . . . made by Western Pacific Trading and sold through West Marine, is that it tends to fray easily and does not make the cleanest cuts even when using a brand new razor blade."
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 6:44am
Originally posted by stang7tl stang7tl wrote:
went with the GTU stuffing box only had 2 standard flax in it and was 1/4" i got 1/4" gtu and installed 2 right was tight to get seated but once in it moved down to shaft with just a little friction. I hand snugged it put boat in water it was dripping when still. LOL
You should be able to get at least 3 rings in the gland. They are separate rings and not one length wrapped around the shaft in a spiral. The ring joints are staggered. If the gland runs hot, the packing nut is too tight.
Here's a nice tutorial on the procedure
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 3:01am
That seal is not dripless, it should drip a few times per minute to lubricate and cool the seal.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang7tl Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 12:51am
went with the GTU stuffing box only had 2 standard flax in it and was 1/4" i got 1/4" gtu and installed 2 right was tight to get seated but once in it moved down to shaft with just a little friction. I hand snugged it put boat in water it was dripping when still. So i tightened it a little more by hand till it stopped but I didnt get a chance to run the boat at all b/c of getting eaten alive at the dock LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 9:47pm
Originally posted by baitkiller baitkiller wrote:
Use the GTU. Be careful not to over tighten it.
The Gortex brand is "GFO".
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 8:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang7tl Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 6:53pm
I'm am new to inboards I have a 74 southwind. I am changing the packing out I have PTFE Flax available and the GTU. What do u all suggest? I am not keeping the boat in the water. But I do run in saltwater. Please help lm looking to do tonight or in the am and get on the water :)
