  New Posts New Posts RSS Feed - What would be a good replacement battery for my SN
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Topic: What would be a good replacement battery for my SN
    Posted: June-21-2013 at 9:57pm
go figure I post and then today I get ready to hit some evening skiing only to have a dead damn battery. If anyone is curious a marine starting 65 series is too tall to fit in the battery box of a 94. had to go with a regular 65 series. But got 8 years out of the last advanced titanium so I'm more than happy. Bought the same thing even though the price is now through the roof...geez $147 for a battery. Here's to another 8 years!
Pete I don't have any draw issues, I just have a unique setup meant for marine use. I have an auto bilge, vhf/uhf radio, and auto gps on my bigger boat so that unless I have the boat in storage those 3 things are always on regardless of ignition position. So I have the switch to kill those when its landlocked. The combine battery switch is for any bad luck I may have when I'm 3 miles offshore. Cells die at bad times and to me a combine battery switch is a requirement for anyone going in the ocean. All it takes is a bad/stuck relay to drain a battery.
'94SN Restoration underway...
80SN Barnfind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80SN Barnfind Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2013 at 9:47am
I've always run Deka batteries by East Penn in all my boats & vehicles. Very satisfied with their performance and longevity.
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2013 at 7:52pm
Originally posted by Foot_Fungus Foot_Fungus wrote:
The rotary switch lets me kill all draws when its in storage and then gives me the ability to use both batteries to start if my starting one has an issue.
If you keep a trickle charge on it and ensure it doesn't get drained to zero you'll get the best track record with it.
John,
You may want to run a parasitic load test since I feel you have a problem. Storage drain? I routinely store my boats from Labor day to Memorial day in the dead of winter in northern Wisconsin. Batteries are keep in the boats without any maintenance chargers hooked up. I have NEVER had a problem starting any of them come spring and in fact don't even hook up the charger. This spring just for the H*** of it, I did on the Tique. The charger only went up to 2 amps!!
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2013 at 2:52pm
gsyogi, I'll be happy to share photos and any details once we get to the stereo phase of our "project". We just bought the boat and are still going through the mechanicals and wiring (no problems so far, I'm just kind of anal about not having issues on the water if I can help it). Then I need to teach my 14 year old how to make the boat shine, and we are also looking for an affordable wake tower (gasp) solution. He wakeboards and my daughter slaloms, and both want the tower for towing, to clean up the interior (board racks), and of course to be "cool". I know some folks feel they ruin the lines of these classic boats, but I actually like the looks of some of them. I'll need to find wake speakers to mount on the tower, and then I'll get to the amps and stereo battery. The main reason I'm going to go with a separate battery is because a lot of owners are running lead ballast under the bow anyway, so I might as well make my lead something useful (and isolate my starting battery). I agree 100% with Foot_Fungus that a battery's life depends heavily on how you care for it. My boat batteries spend Wisconsin winters in the heated garage, and I teach my kids to check the electrolyte level and to keep the connections and batteries clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2013 at 1:52pm
On that note I will also say that there are only a handful of battery mfgs left, namely Johnson Controls and Interstate. What you are paying for between labels is mostly warranty length and ease of trade in. The amount of use you get out of a battery is largely dependent on how you take care of it. If you routinely let it draw dead and rapid charge it you'll shorten its life. If you keep a trickle charge on it and ensure it doesn't get drained to zero you'll get the best track record with it. Optimas are great, but a little over priced in my book unless you are worried about battery acid leaks and/or need unique sideways/upside down mounting locations. Optimas also tend to hold up to heat a little better. I usually go with the brand that has a store closest to my house. I've had very good luck with mopar/interstates and the advance auotparts titanium line(longest warranty).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2013 at 1:43pm
For a stockish stereo I'd say you could get away with running a single battery and a battery draw switch. The draw switch will automatically cut off the stereo, or any other power draw, when the battery goes below a certain voltage setting. They're fairly cheap and effective. In general you should be able to run your stereo for an hour or so with no starting issues. The switch just gives you the piece of mind that it will turn it off when needed to ensure you have starting power every time.    As soon as I put in the new stereo this is the route I will be going. On my big boat which has 2 amps and color gps I run dual batteries(one being a optima blue deep cycle) with a Blue Sea isolator/auto charge switch and a rotary on/off/dual knob. The isolator keeps the batteries from drawing off eachother and auto switches the alternator charge to the battery that needs it. The rotary switch lets me kill all draws when its in storage and then gives me the ability to use both batteries to start if my starting one has an issue.
gsyogi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsyogi Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2013 at 11:42pm
Now I wish I would have waited a couple of more days ... just ordered a Optima D34M "blue"/dual purpose for our '94 SN family skier ... I will let you know!? "Boardersdad" ... I would really like to see some pictures and other data on how you configure your stereo, i.e., dual batteries and amps, as I am getting read to add a stereo upgrade on our boat (for now, at least, I am going to stick with a single battery ... hence the Optima).
jbach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbach Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2013 at 11:06am
Originally posted by Big Pappa Big Pappa wrote:
Do some research on the optima, I have read a lot of occasions on where the battery died fairly early in their life. I was dead set on an optima when I was looking but all the reviews made me change my mind. Everyone does not have a bad experience with them but enough did to make me not want to risk my money. Hope this helps.
Kris
optimas have been hit or miss since they moved manufacturing to mexico. mostly miss. they can not seem to get it back together. if you think you need an agm, in no particular order;
exide orbital
diehard platinum (rebranded odyssey)
deka intimidator (note; most napa batteries are rebranded dekas)
odyssey
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2013 at 1:09am
As I have said many times before I have never bought a battery for the boat. The one I have now is out of my Jeep,the car always gets the new one. My Dads boat,with a 302 Pleasurecraft is still using the original battery out of his '00 Lincoln,try beating that with any high dollar battery Matter of fact all the 100+ fleet trucks where I used to work switched to Motorcraft batteries because they lasted so long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2013 at 12:47am
Great thread, thanks.
We recently bought our first wake boat, a 1984 SN2001. I've got the floor up and some engine parts off making everything "just so". The battery from the previous owner is too tall for the compartment (in the middle between the two seats, like TRBenj mentioned). So I came on here looking for the right battery group size to buy.
Group 34 batteries are 10-1/4" L x 6-13/16" W x 7-7/8" H.
Group 65 batteries are 12-1/16" L x 7-1/2" W x 7-9/16" H.
(from BCI Battery Group Size Chart)
For the 1984 SN2001, I'll be looking at the Group 65.
I'll eventually be adding a stereo (already have the amps), but I'm planning to put a battery box with a deep cycle up under the closed bow, where many owners put a ballast weight, anyway. The amps will be mounted under there, as well. So I'll stay with a starter battery within the CC-supplied battery compartment.
Like Donald80SN, I always turn off the engine when skiers and boarders are near the boat. Our other boat has a 40 year old Mercruiser 140 I/O. Previously, the longest-lasting battery I had was a dual purpose bought from Batteries Plus. It lasted 7 seasons. Then I bought a WalMart battery, which I replaced after 6 seasons (it probably could have gone longer). Then I bought another WalMart battery--this is it's 7th season, and it is still very strong.
I see online that WalMart has several Group 65's in their stores. I need to check our Mercruiser battery to see if it was the EverStart Plus or the more expensive EverStart Maxx. I think it was just the Plus or even the more basic battery. Given the great luck I've had with WalMart batteries, I think I'll put one of their Group 65 batteries in the SN2001.
My current WalMart batteries are made by Johnson Controls. They used to be a customer of mine, and years ago they had the contract to manufacture the Sears DieHard, which is a great battery. It's interesting to talk to their engineers about any (meaningful) differences between these various brands.
Thanks, guys, very helpful as always.
edit: I forgot to mention that cranking the 351W will obviously be more demanding than cranking the 181 cubic inch 140, so it will be interesting to see how many seasons we get out of a battery in the SN. On the other hand, the stereo in the Mercruiser boat runs off the starting battery, and it gets played a lot (pretty loudly, too, when we're anchored at a sand bar). I start the engine now and then to give the battery a little charge.
karthur View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 1:42pm
I was leaning toward the Optima D34M. My local Autozone didnt have it the day I stopped by or I would have bought it. I have since looked at the Diehard 34M and it looks like a better battery and you get another yr on the warranty. Hopefully, it will last much longer than the warranty since I will only be using it 3 months of the yr. and it will be stored inside away from the cold in the winter.
The Odessey battery that was mentioned above is $346. A little more than I want to spend.
Optima $210
Diehard $220
HatterBee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HatterBee Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 1:06pm
I have used the DieHard Platinums for many years and have not had any unusual issues. When I was in the car stereo business we used the automotive diehards exclusively. The marine batteries are good and Sears is pretty good in holding up on their replacement warranty which I believe is 3 yr replacement.
1977 Ski Nautique
Under Re-construction
My Rebuild Thread
randall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randall Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 12:25pm
KARTHUR, which one did you end up getting?
I think I am narrowed down to DieHard platinum 34m or Optima blue 34m.
1973 CC Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 1:20pm
Group 65 works great for mid-late 70's boats and newer, when CC was putting the battery in the middle of the boat (between the 2 front seats or slightly forward of that). A group 65 will NOT fit in the under-seat battery compartment of the 60's and early 70's boats. I do not recall what size battery Im running in the Skier and Mustang, but its smaller than a 65.
Big Pappa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 12:07pm
Originally posted by randall randall wrote:
Thanks all.   I know, search, search.
Diehard looks great. 11.8'' length looks tough. My compartment hole is only 11.5'' roughly, I measure (with carpet trim).
If you can make a run by sears and see if you can find a group size that will work for your boat. Mine was for an '85 2001 so the 65 worked perfectly. You probably can find a smaller group size that will work for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randall Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 10:59am
1973 CC Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2013 at 2:29pm
I just replaced mine last year and after doing some research I decided to go with a Dihard Platinum battery in a group 65 size. From my research this is just a rebranded Odyssey battery. I can tell you that this battery spins the motor effortlessly. It sat all winter with no charger on it and when I pulled it out this spring the charge was still full (I put my charger on it but it did not even start and told me the charge was full). Now granted I do not have a stereo in the boat yet, I have no doubt that this battery will do the job no problem.
Kris
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2013 at 12:41pm
The search feature is a wonderful tool!
Group 65
Post Options Post Options   Thanks (0) Thanks(0)   Quote randall Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2013 at 12:33pm
Thanks.
As the years go by, it seems the battery compartment size is becoming more of an issue. I went to a large boat dealer yesterday and all the marine batteries (interstate, others) were too tall.
I have a ac/delco 660 cca battery now and it is playing out.
Optima is quoted as "15 times the vibration resistance and lighter weight. ". I would think that would cover the marine batteries built for more vibration and jolt.
The optima 34m 800 cca looks very attractive.
1973 CC Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2013 at 12:11pm
My QUESTION, does bilge pump and bilge fan really put us in a category of DEEP CYCLE too??? or is this still within the parameters of just a STARTING battery.   Don't run bilge pump much, but fan a good bit.
Unless you are running the bilge blower and bilge pump for hours and hours without the engine running, no, their load is not the long term low amp draw where a deep is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randall Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2013 at 12:06pm
Looks like I am in the market for a new battery too.
I have no stereo. But have dashboard depth finder.w
My battery compartment is pretty tight. I need '>8'' height.
Optima 34m blue looks very attractive.
1973 CC Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 6:38pm
The 34m is not what you want- that's just a starting batt like the red top. Either the d34m or yellow top would suit your dual purpose needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 6:19pm
Thanks for the posts guys. Looking seriously at the Optima 34M (Blue top). Has 800CCA and 100min reserve. If it will fit, that's the one I'm going with.
Will 800CCA be enough for the 351?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 5:01pm
A starting battery is meant for a high current draw over a very short amount of time. A deep cycle is meant for a small, slow current draw over a long period of time. Neither does the other very well, which is why you often see guys with larger stereos adding a second deep cycle batt in addition to their starting batt.
Since you're not talking a huge current draw over an extended period of time, a dual purpose battery would suit you well. Optima makes a dual purpose marine battery- and they also make a starting batt so make sure you buy the right one. Optima is the only name I know by heart, but there may be other good dual purpose batteries on the market as well. Might be worth looking into them.
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 3:42pm
I second the Optima blue top. Mine has always come through for me... knock on wood for this weekend ...
I like the fact that it is gel and if something goes wrong there won't be battery acid leaking all over the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 3:21pm
I have the Optima Blue Top ( Starting only) battery in my 1980. I love it, I also had the Blue Top Dual Purpose in a pontoon boat that I sold last year after using that battery for many years. Blue is for marine and the other colors are for on road and off road. It is probably just mental, but the Optima's always seemed to start better. I realize that really does not make sense when you are talking about an electrical circuit. I am just paranoid about the boat not starting in the middle of the lake. I always turn it off and on when working with sking and such.
Many on this site will tell you that an expensive Optima is not needed and they get many many years of service from Walmart Brand Starting Batteries. Just be sure to use a starting battery and not a trolling motor battery.
I hope this helps,
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2013 at 3:02pm
Anyone care to comment on what cranking battery they are using in their boat? I am looking at replacing mine. I dont have a big kicking stereo, but sometimes we will sit in the boat with the stereo on for an hour or so. Once last yr, it scared me a little cause it was really slow to turn over and start. Would hate to have to flag someone down on the water for a "jump".
Been looking at the Optima batteries. Don't mind spending around $200 for one of these. I just dont know which one (red, blue, yellow) would be the best to turn my 351PCM. Maybe I just get the biggest one they offer.
Can't wait to get back on water this year.
