351W Timing Chain |
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
Posted: May-31-2013 at 11:48am |
Thanks Gary. I saw the one at Summit and was planning on getting a few other things there.
- Jeff
1999 Ski Nautique |
Maybe others can chime in but I'm not a fan of buying internal engine parts from ebay. If you stick with a known supplier,you can return easily if need be,and should be name brand parts not some chinese copy. Cloyes double roller would be good,here are some others to look at.
ny_nautique
The timing chain is the last thing I need to take off my block before I bring it to the machine shop. I'm seeing a few different options on eBay and a few other retailers. For instance,this one says it is for up to 1972.
I searched for a 1984 F250 with the 351W and found a bunch. Here's one and here's another. Suggestions? |
- Jeff
1999 Ski Nautique |
