  New Posts New Posts RSS Feed - Stuck Tachometer Needle
winniskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Topic: Stuck Tachometer Needle
    Posted: June-04-2013 at 10:51pm
I decided to pull the tach tonight. It turns out that a wire was disconnected. After reconnecting it, the needle moved when I cranked the engine. It was not so much stuck as unmoved. The tach does not settle to zero when the engine is off. I'll see what happens when I run the boat in a few weeks and decide what to do from there.
Jim
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 12:08am
I actually may have a replacement Tachometer... Email me a picture. Or at least your boats vitals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 11:04pm
Thank you. I am trying to decide whether I should order the replacement now as the fastest path to a complete fix while the boat is on the trailer. I won't be able to start the engine and test the tach until the boat is launched. Once the boat is launched, my ability to fiddle with it will be limited. I guess I am asking if there could be any possible explanation for the stuck needle than a bad tach. I can't imagine that a a bad wire or connection would cause that.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 8:59pm
It should be able to be repaired.... Rod Velde has a few great places that will do it if you want to keep it original... (Velde99)
It is much cheaper to replace with a VERY close replacement too...
Post a pic, We'll help you track down repair/replacement.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 8:43pm
The needle on my tachometer is stuck at 1800 RPM. The needle does not move when the engine is running. What are the chances that the tach can't be repaired and needs to be replaced?
Jim
