  New Posts New Posts RSS Feed - Battery issue
Battery issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Battery issue
    Posted: June-22-2013 at 7:29pm
Originally posted by Dansmth Dansmth wrote:
I did get deep cycle battery and was planning on adding a second with a selector switch for stereo. Am I going about this wrong? Of course once I get my current issue worked out.
Yes, you are going about it wrong. Why the deep cycle? You do not have a trolling motor that uses a small amount of current over a long time. The starting battery is designed for a large current draw over a short period of time. Sometimes the salespeople at the store are so naive that if you ask them for a marine (not needed), they will sell you a deep.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2013 at 7:17pm
A deep cycle will not work for starting the engine.
Dansmth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dansmth Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2013 at 7:14pm
Thanks for the response guys. I should have some time do the test tomorrow. Will get some pics up too. I did get deep cycle battery and was planning on adding a second with a selector switch for stereo. Am I going about this wrong? Of course once I get my current issue worked out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2013 at 6:56pm
I shut off all of the breakers (out position) when we are not using the boat. The depth finder runs if the breaker is on, drawing power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2013 at 5:26pm
Dan,
First welcome to CCfan. Get us some pictures. We love them.
You have a parasitic load. Follow this procedure
BTW, I hope you didn't buy a deep cycle battery. Automotive starting types are fine. You will find plenty to read here on the subject.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dansmth Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2013 at 4:46pm
New to the forum. Just got 1986 cc put in new battery and won't stay charged. Alternator is charging while running but battery losses voltage slowly while sitting. Had it on the water started right up first to days dead third morning. Last week took it out started up and then dead again after a short swim, BBQ break. Battery was charged in between outings and disconnected
