Fly High pole twisting |
bigwavedave
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 199 |
Posted: July-28-2013 at 9:38pm |
You're not supposed to use the fly height for a salon skier
bigwavedave
Wes1089
Newbie Joined: September-19-2012 Location: NJ Status: Offline Points: 14 |
Update: I was able to significantly tighten the cables by moving the pin to the clip back 1 hole. Much more stable setup now, although no heavy weights rode yesterday to test the slalom tow point. I think the bow strap may have stretched some since we started using it at the beginning of the year.
Thanks for the help... |
TX Foilhead
Run a loop of rope around the pylon and and clip a caribeener on it to hook the slalom rope to. That will take away the leverage the rope has from that eye sticking out.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21194 |
The trick is to get it tight enough that you can just barely clip it yourself. And I mean just barely. If it doesn't fight you it's too easy- and too loose, IMHO. I can't imagine any of mine twisting like that- ill have to check. Admittedly, we take it down for serious slalom.
Wes1089
Mine is defintely not that tight. I will have to check it out.
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
I have mine preloaded pretty tight, usually requires someone to push forward on it while standing on the motor box to get the strap through the clip ring. It ain't moving at all after I close the turn buckle.
Wes1089
@TRBenj, I can't imagine how I would get the bow strap connected if it was any tighter.
@Dip, good call.. We are just in front of the Trenton Power Plant. |
dip
Senior Member Joined: August-29-2009 Location: Eastern PA Status: Offline Points: 392 |
Mine does that too. The cable is too high up to prevent it from twisting when line is attached at the normal pylon height, plus the face mounted ring gives the line leverage to twist it. I wouldn't worry about it. Where are you in that video? On the Delaware south of Trenton? It looks too narrow.
I sure would think so. How easy is it to clip the turnbuckle to the strap? It should be moderately challenging. The forwards load from the turnbuckle being tightened should not allow movement like that. |
Wes1089
So I am hard at work making a movie from last weekend's skiing and I noticed that my fly high pole twists considerably with a slalom skier.
What do you guys think? Cables too loose? It is what it is? Fly HIgh Twisting |
