  New Posts New Posts RSS Feed - Windshield Screws
Windshield Screws
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Topic: Windshield Screws
    Posted: August-17-2013 at 1:21am
oh btw, those part numbers assume your 1/2 inch #8...
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2013 at 1:18am
Steve K,
I'm wondering if you and Tim have your wires crossed. He said "Those look perfect", referring to the photo, I believe.
I get the impression you are looking at these from MC:
90356A259: Pan Head Phillips Screw for Sheet Metal, Black-Oxide 18-8 Stainless Steel, Number 8 Size, 1/2" Length
You need to measure the head diameter on an existing windshield screw. The screws in the photo look to me like either Round Head (94005A411) or Truss Head (93406A195 or 93406A194), not Pan Head, but it's hard to tell from that photo. Neither are available in black from MC.
I think they're truss head, but it's hard to tell at that viewing angle.
Steve
shagit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagit Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 11:56pm
Thanks!!
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 11:31am
Sure - will do!
I'll keep some screws on file for ya......
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 11:20am
Steve, dont worry about me- if and when I need some, I wouldnt be able to put my hands on the ones you give me and I'd need to order a new box anyways.
Post up the part number you determine to be correct though- that'll help a lot of people!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 10:54am
So far I've got:
Rod
Mike
Tim
Measured screw(s)- 1/2 inch long look like #8.. Will confirm this weekend..
Going to place order...... let me know who needs them - looks like I'm getting the 100 pack.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2013 at 12:51am
Will do Mike - Get Rod to measure his loose screws to make sure. I haven't gotten to my BFN to pull a remaining screw yet... 3/8 inch?
Tim- So you are saying the Mcmaster-Carr screws are correct - right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagit Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2013 at 12:46am
I'll probably need a few of those.... I have a 91 and will be eventually removing the windshield frame to have it anodized black...
Let me know if you need a few bucks...
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 9:56pm
"break out the micrometer on an costing screw"
Huh? Now you are using "fancy-talk" on me................
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 9:54pm
The McMaster-Carr look perfect? The ones pictured are an image stolen from another member doing a refurb (He has no others)..... I have asked him to measure but haven't heard back.
If they are correct, I'll buy 100 and distribute to anyone who needs them...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 8:45pm
Those look perfect Steve- break out the micrometer on an costing screw if you want to confirm the size. No extras here but I know where to find some now if I need some!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 7:51pm
I might just stay local and paint them, if black oxide is cheap and on potentially rusting stock.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 7:50pm
This is what I am getting from McMaster-Carr:
#8 3/8 inch (I think) SS Sheet metal screw - says Black Oxide finish Stainless Steel
And they look like this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 7:36pm
Steve,
Black oxide is a very cheap finish typically used on carbon steels. You'll see it alot on fixturing for machine tools. I've never seen it used on Stainless.
If i'm following, the screws needed are a "truss" head. The heads are bigger in diameter. If "push came to shove", you could always go to a well stocked hardware store, get the screws and paint them black?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 7:22pm
OK..... isn't black oxide a finish on Stainless Steel? So, it will rust? What do I get then on a black windshield ......?
(Man, I cannot seem to spell windshield for the life of me!!!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 7:18pm
Steve,
Stay away from the black oxide. The coating isn't very rust resistant.
If you don't get an exact answer, see what screw size will fit the hole and then measure for the length needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2013 at 5:58pm
Looking for missing screws - 1991 BFN windshield.... Upper corner and side wing. Site search didn't help. Jody rec'd McMaster-Carr which is great starting point but I don't know length, size or if they are black oxide SS or painted SS.... plus they sell packs of 25-100 (a little more than I need!)
Anyone have a few laying around----- Zach? Tim? Townsend?
