  New Posts New Posts RSS Feed - ARE shaft question
ARE shaft question
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: ARE shaft question
    Posted: August-24-2013 at 6:34am
Originally posted by rfarkash rfarkash wrote:
That makes sense. Guess I was focused on the fretting that can happen with a simple press fit.
Ron
Ron,
The fretting comes from a misaligned shaft and is not caused by a press/heat shrink fit.
rfarkash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfarkash Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 10:54pm
Anyways, got the strut and shaft installed tonight and am pretty psyched with the results. Shaft just about perfectly centered in the log and spins like butter. 5200 cleaned up with acetone and no sticky mess. Gonna let it set up overnight then align engine tomorrow so we can water test and hopefully use the boat this weekend.
Thx
Ron
Ron 1989 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 6:44pm
Ron,
I missed answering your question on "coupling failure". It's not the coupling that fails, it's the shaft that breaks. They will break if the alignment is off. Every revolution of the shaft causes flex and the from fatigue the shaft breaks. So, it doesn't matter if you have a single or double taper shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 5:54am
Set screws enough to hold shaft in the boat if coupler fails? Is that basically a non issue with the double taper shaft?
It doesn't matter if you have a single or double taper shaft, no dimples are needed for the shaft "safety" collar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfarkash Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 1:16am
Bones71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bones71 Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2013 at 10:50pm
Ron, I had a full collar on my old shaft before I got my ARE. I put it on my new Are shaft. No dimples to drill. Just set screws to hold it in place. Get it on. You'll love it! Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfarkash Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2013 at 10:47pm
Just got my replacement ARE shaft - wow! It looks so good I'm hesitant to put it on - just want to put it on the workbench and stare at it - it's a piece of art.
Anyways, noticed there are no dimples for a safety collar. What do most of you running these shafts do? Split collar? I would be pretty hesitant to drill dimples into this.
Thx
Ron
