  New Posts New Posts RSS Feed - Starter bendix won't disengage
Waternut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Topic: Starter bendix won't disengage
    Posted: September-11-2013 at 1:19am
Ok so this starter has no bendix return spring. Instead it used the solenoid to actuate a plastic lever which pushes and pulls the bendix. I disassembled my starter again today and realized it had popped out of that plastic lever originally. I didn't put it back in because it looked like it was designed to self seat but this is not the case. After putting the lever on the bendix properly, it works fine and the bendix retracts appropriately.
No idea how or why it came out in the first place but it's fixed for now.
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2013 at 12:35am
I assume you checked the spring on the bendix return? those like to snap and wrap in on themselves. If you pull the gear out by hand it should snap back with a loud clack.
The other thing I would check would be the ring gear on the flywheel. sometimes the welds come loose and it tweaks the outer ring a bit.
'94SN Restoration underway...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 9:29pm
Engine fires right up and no voltage to the starter once I let off the key. Gotta be a solenoid or bendix problem unless it has nothing to do with the starter completely. Trying to get my hands on a friends old starter since I was dumb and sold my old starter to a friend who killed his.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 7:55pm
Yes, I agree to get the VOM out and check to see if the starter is still getting power. Considering you did have alternator and battery problems, that may indicate a bad battery causing a low voltage and a high amperage across the start relay. It will weld the contacts together. Hopefully you do not have a deep cycle battery that is being used for starting. That will give you grief as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 6:58pm
It's hard to tell if the starter is still powered and spinning or whether the bendix is stuck out. I guess I can check the voltage on the starter...can't believe I didn't think of that earlier.
If there is voltage, I'll bang on the relay and see what happens.
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 6:26pm
are you saying that your starter stays engaged after you release the key while the engine is running? Could be the starter relay is stuck. Tap it with the plastic end of a big screw driver???
83Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 5:34pm
Hey this is a 5 month old starter from Skidim for a 351W. Probably has 100-150 hours on the engine since it was installed. The starter turns strong and starts the engine without any problems. However, once started, there is a horrible clanking noise that I believe is the bendix hitting the flywheel.
I pulled the starter and lubed up the bendix gear. It moves smoothly until it's in the starter housing though and then it doesn't like to go back down. I put it back in the boat and nothing changed. I cranked it up and tried to pull the small wire that activates the solenoid but nothing happened.
A little background that may help... The alternator randomly quit about 2 weeks ago and killed the battery. I recharged the battery and it continued to work fine. The day the problem started, I pulled the front bowl on the carb to change the power valve. Didn't seat an o-ring properly and fuel was gushing out so I shut it down quickly but I don't remember the starter issue then (could've overlooked it due to fuel spraying though). Anyway, fixed the fuel issue and hosed down the engine and bilge. Took a little work to get it started again but I never held the starter for more than about 10 seconds and when it started, the clanking noise was there.
