  New Posts New Posts RSS Feed - propeller
propeller
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: propeller
    Posted: October-16-2013 at 7:58pm
Plus a good prop shop sometimes run a reamer down the prop changing what you had.
Exactly! The reamer used may not match the shaft taper! Lap it on.
Yes, get a prop puller.
PNALEWAJK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2013 at 1:59pm
Okay. Thanks guys!
Corvette Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2013 at 2:24am
Bones71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bones71 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2013 at 1:12am
Peter, it really doesn't take long to do. It's easy. If it's never been done on your boat it's good peace of mind knowing you did it right. If you bought the boat and never changed props how do you know if it was properly seated right on the shaft in the first place? It's one of the easier things I've done in my adventures this year. Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Post Options Post Options   Thanks (0) Thanks(0)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2013 at 11:31am
That looks easy enough, but is it necessary if putting the same prop on the same shaft?
Corvette Pete
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 9:03pm
Lapping is easy. You should do it.
Steve
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 7:18pm
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Post Options Post Options   Thanks (0) Thanks(0)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 2:12pm
Thanks. I'll see I can borrow a puller. Can someone explain to me about "lapping" and if I need to do this if I'm putting the same prop back on?
Corvette Pete
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 1:25pm
A puller is a great investment.
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 1:20pm
1- get a puller
2- you got a marina or a repair shop near you? They probably have one and will let you use it for a few bucks.
you could try getting a block of wood behind it and tapping it with a hammer (repeat- TAP), but you're asking for problems if you miss. Either way, after you loosen the nut, leave it on the end of the shaft, that will keep the prop from hitting the sidewalk when you get it loose. They don't bounce well.
bring the ruckus
2000 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote PNALEWAJK Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2013 at 12:37pm
I need to have my prop worked on (hit a stone). Any suggestions on how to remove it from the shaft? I don't have a puller.
Corvette Pete
