  New Posts New Posts RSS Feed - 1970 Mustang Prop Shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Topic: 1970 Mustang Prop Shaft
    Posted: December-12-2013 at 1:10pm
I have a used 40" shaft that has been put on a dial indicator and is less than .003" out that I'd sell for $75. If money is not an issue, I'd go with a new double taper from DIM, also.
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2013 at 12:55pm
One suggestions is Discount Inboard Marine. Great to work with, should be able to give you good advice. If you decide to get a double taper shaft, I believe they can get you cheaper for you than you can get it from the manufacturer.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
benkiefer84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote benkiefer84 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2013 at 6:49am
I need a prop shaft and strut for a 1970 Mustang. if anybody can give me any information on part numbers or places that may have one I would be greatful.
