Hey, another wiring question! |
Bri892001
Posted: December-28-2013 at 11:30am |
^^No problem Matt, glad to help.
JP, I added some more pictures related to adding the positive bus bar, on the Dash Ground Thread This is one of them: |
P71_CrownVic
Gold Member Joined: July-07-2008 Location: SD Status: Offline Points: 534 |
My mistake. The amp is connected to the battery, but the stereo will only come on when the accessory breaker is engaged. I believe that with the ignition breaker off, the accessory will still function, but don't quote me on that as the boat has been asleep for the winter and I frankly can't remember 100%. Bri: Your explanation was fantastic. Thanks! |
JPASS
I look forward to the pics. I plan on adding a hot bus bar myself in the future.
'92 Correctcraft Ski Nautique
Bri892001
1.) CC Daisy Chained a lot of the grounds. Horn, etc. In the case of the gauges, the grounds often have to do with just the gauge lights. Mine had some grounds for the gauges themselves. But, they may have just been place holders. Keep in mind, the sender wires do their jobs by providing variable resistance to ground, which gives variable readings. So, you never want to ground a sender wire directly to a solid ground, or it will just peg all the time. 2.) It's up to you whether you want to leave the daisy chain in place, and just run a secondary connection to the bus bar, or remove the daisy chain. The beefing up method is a little more idiot proof, because you have a backup in case you miss a connection to the bus bar, but it does leave that hairy tangle of wiring in place. I'm planning to add positive bar as well. It would connect the OUTPUT side of the ignition breaker, to the INPUT side of all the other switches, including the key. You just don't want to connect anything downstream of the key directly to your positive. As far as positive, there are two switches mainly: Red: Everything that gets it's power from the main ignition breaker, this includes the input side of the key Purple: Everything that gets its INPUT from the OUTPUT side of they key. I plan to post pics of the Positive, RED, bussbar I've started making, but having some home computer issues. |
dwouncmd
Gold Member Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
I have a 1 Farad (1 million micro farad) cap that I used many years ago for car stereo. I never realized how dangerous it was until recently. A cap that size could easily kill a person. Anyway, the caps go inline on the positive wire with an appropriate in line fuse close to the cap and close to the battery.
Having said that, a heavy gauge ground is a directly to the amp/battery is a cheaper/easier first try fix. I am planning a bus bar for better grounds for the 89 and the 78 someday... |
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
FLA (full load amps) should be added up which will give you an idea of the wire gauge to use. Don't forget to factor in the length of run. |
Dreaming
Key words - SMALL CAPACITORS |
KRoundy
I remember back in college in our Engineering school we would take small capacitors, charge them up and then put them back in the supply drawers or just leave them lying around. When somebody would pick them up... BAMB! I got zapped once or twice. Good times. |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
Maybe you should just start with adding the additional grounds then try the stereo. That may fix your problem. Also, you said that the PO used a proper amp wiring kit but then you said the stereo/amp are connected to one of the accessory breakers. The amp wiring kits that I have seen connect a large gauge wire directly to the battery. The accessory wire won't handle an amp very well and would cause the problems that you are having. If you want to be 100% sure about how the accessory breaker is wired just turn off the ignition breaker and then see if your stereo will turn on.
P71_CrownVic
I would have to look. I only have one sub either a 8 or 10". It's a cheap one from Wal-Mart. But that's a good idea. I'll definitely look into it.
Dreaming
Matt,
I would suggest that you add a capacitor for your bass situation. The sub in your boat is the least resistance to ground, and therefor the path the power takes, instead of going through the proper accessory and factory wiring. the capacitor is like a quick charge/discharge battery that helps to smooth out the draw and spike that you are experiencing on the stereo side. Your local stereo shop should have experience with this issue as it is common in vehicles with a large sub/amp set up as well. you can probably buy the cap from crutchfields or other online sources. check prices before you get in over your head at the local stereo shop. I am not entirely familiar with how to wire the cap, nor am I sure that an open cap on a boat would be a good Idea..(discharge from a cap can kill you) be careful to handle it properly if you do go this route, and make sure that things are above any possible water line or intrusion. maybe a more technical question, but one you need to explore... how many ohms are your subs? do you have them wired in series or parallel? one causes the resistance of the system to go down, causing more power draw. good luck! |
P71_CrownVic
Wow, lots of good info here, thx guys.
Pete, as far as addressing the positive side, how would suggest beefing that up? i don't think it needs much, the PO did a great job installing the amp and used a proper amp wiring kit. Having installed systems in vehicles before, in my opinion, everything looked good there. Desert, The stereo/amp are connected to the accessory breaker which will work independently of the ignition switch (I'm 99% sure on that). Everything else is ignition controlled (gauges and such). So would it benefit me to get a dual buss bar and run a heavier/additional positive wire from the bar to the accessory and ignition breaker (or do I skip the ignition breaker and run it to the key)? I think I have a pretty good grasp on correcting the ground issues. The positive side is a little more intimidating. |
desertskier
As far as your stereo goes you should have the positive for the amp connected directly to the battery through a fused wire. The fuse should be as close to the battery as possible. The head unit should have an amp control wire that will turn the amp on and off but does not provide power only control (the amp has an internal relay that is switched by the head unit). The head unit positive should be connected to the output of the dash ignition breaker so that it will be disconnected when you turn off the breaker button. As suggested add a ground buss bar. Home Depot had some nice ones when I was there the other day or an electronics store. Connect the negative for the amp back to the battery negative or engine or the new buss bar and connect the head unit negative to the buss bar. Depending on how big your amp is it may draw a bunch of current and would be best to give it the best ground possible. As Mr. Brainard says the grounds are only part of the problem. The additional wire I mentioned from the positive battery terminal up to the ignition breaker (use the Y connector as mentioned in the other posts like Jpass used) to connect it and the additional wire from the other side of the breaker (using another Y connector) over to the key switch will reduce voltage drops and give you good battery voltage at the key. If you have any additional loads like your stereo head unit or perfect pass that you want to come on with the breaker then you will have to provide a wire coming directly from the ignition breaker (use individual wires for each load - no daisy chaining - although you can crimp or solder a few wires together and then attach just one end to the breaker terminal). Any loads that you want to come on with the key must have an individual wire from the output of the key switch to the load (does perfect pass come on with the key or ignition breaker? I have never had one). The primary load from the key is electronic ignition if you have it. In the case of ProTec this is a big deal but my "new" '89 just has a Mallory conversion so I don't think it needs much current. I measured the voltage at the ballast resistor and it was pretty close to the voltage coming out of the key so I am probably OK. You may want to make a similar measurement. I may still run an additional wire from the key back to the engine, not sure yet. The other loads from the key are the gauges which should be OK with the existing daisy chain (in my case the wires are purple) if you wanted to go above and beyond you could add a buss bar for the positive side of the key and connect all the gauges and whatever else is connected to it. Or just spice into the chain a few different locations then connect back to the key (I may still do this also). Like I said I just bought the boat but it is pretty well disassembled at the moment. It needed a dampener plate and since I had the tranny out I decided to install a new strut bushing.
Matt,
The voltage drop problems are not only related to undersized ground wire and daisy chains. You need to address the + supply as well. |
JPASS
Feel free to check out my Thread when I ran new grounds.
I ran a new ground from the motor to the bus bar. Then I added a "Y" spade to the rear of my gauges with the new grounds going straight to the bus bar with the next gauge thicker wire. This solved a lot of my problems, but not all of them. Check all of the other connections as well. They might need a quick hit with a wire brush or emery cloth. I've replaced many of the terminal ends on the original wiring. |
desertskier
I bought an '89 a few days ago (I have also owned a '92 since '93). Since I already knew about the wiring issues I figured I would just clean this one up from the start. One of the PO's had already installed a buss bar for the grounds but only connected some of them. The gauges still jumped when I turned on the nav lights. Since the buss bar was already there I just spliced into the gauge grounds at the voltmeter and the tach then connected individual wires from those points to the buss bar. This corrected the gauge problem. Depending on how much work you want to do you could run a wire from each gauge to the buss bar but I don't think it is necessary. I added wires that will connect the ends and middle of the daisy chains together so that there is a parallel path to ground. I also ran a ground wire from the negative battery post to the buss bar (this could also be connected to the motor if you wanted). The PO had run a wire from the positive battery terminal to the ignition breaker so I just added a ground to go with it. I also ran a wire from the output of the ignition breaker to the ignition key switch (red wire). This is just to make sure that battery voltage is going straight to the key. Since the output from the key switch goes to all the gauges and the motor I thought this would be a good idea. Basically you want to run additional wires in parallel to the existing wires to reduce the resistance back to the motor and battery. Any time a wire goes through a connector or crimp there is a possibility for additional resistance. If you follow the black and purple wires through the dash you will see what is meant by daisy chaining or serial wiring. One wire goes from one crimp connector to the next and then the next and so on.
P71_CrownVic
First off, yes, i did search and did do a lot of reading. This thread was particularly helpful:
Click! But, questions remain. I have a few issues that I would like to correct. One is the ever common gauge jumping when different accessories are turned on. The other issue is similar. I have an amp and small sub in my boat as well. When the bass hits, the gauges really jump around, causing some of the warning lights to light up and if I have it up high enough (not necessarily loud but just more bass), the head unit will reset on me. I think they are all related to the ground issues with these boats. I have the boat torn apart as I'm in the middle of doing the dash plate and think this would be a fantastic time to give some attention to my grounds. So, my questions are: 1. There is a lot of talk about the daisy chain of grounds...is that only referencing the gauges and their daisy chain? Or did CC daisy chain other grounds? 2. Would I benefit from running an individual ground from each gauge to a ground bus type of device? Or just leave it and beef up the wires from the block or add a heavier ground in addition to what's there? The thread linked above is extremely helpful, I just want to make sure I'm understanding this correctly. Thanks, Matt |
