86' Fish Nautique (gettin' put to work) |
Post Reply | Page 123> |
Tracey174
Newbie Joined: February-11-2019 Location: Florida Status: Offline Points: 3 |
Posted: October-21-2019 at 12:57pm |
Tracey,
What diesels are you thinking about? |
Tracey174
No, unfortunately when i bought it the motor and transmission had been removed. I basically bought hull and electronics. So since doing a complete engine anyway thought that a diesel might be cool. Maybe 150-200 hp range. I could build a 350 for it easy enough but i want to stand out.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
Is the 350 still running well? Curious why you want to repower.
Tracey174
I bought this boat, seriously thinking that I'm going to put a diesel in it.
jman161
Newbie Joined: January-06-2017 Location: Biscayne Park Status: Offline Points: 8 |
WOW MOB!!! Awesome Restoration!
MOBCHARTERS
Newbie Joined: December-30-2013 Location: United States Status: Offline Points: 27 |
Well, My new boat is in the water... She is officially up for sale. Way to many features to list but here are some of the big ones. Motor is a 2015 freshwater cooled Marine Power 350 small block bored .20 over with vortec heads and Holly carb (300hp) aprox 200hrs. Vhf is ICOM 504. 2 GPS (Lowrance HDS 8 Gen2 and HDS 5) They are networked together with side scan and down scan. 3 bilge pumps on 3 float switches one 2000 rule and 2x 1100's. All new wiring, switches,and lighting as of 2013. Onboard battery charger. (A good one $300) and a year old 4D AGM battery ($600). You can leave everything on for a few days and be fine. Lol.. There are 2 live well pumps (1100 gph) and one 20 gal livewell. 12 rocket launcher rod holders just on the t-top 4 on leaning post. One large fish box built into the deck foward. Large 5' wide 3 step custom aluminum dive ladder that can easily come off with pins for the swim platform on the stern. This boat is used currently for charters and is set up for fishing in the gulf. I've put over 10k into her in the last 3 years. We are doing a fresh paint job right now and will be putting a fresh coat of bottom paint on her this week as well. Was a gray/blue now is green. Running a 4 blade prop and have a spare 3 blade. 80 gal fuel tank, and with 2 people full tank will cruise 22 mph at 32-3400 rpm and burn 1.75-2 mpg. Serious offers only.. no trades.. Sea-trial if you show me $$$.... $15,000 or best offer. More photos by request these are just what's on my phone atm. Boat is in the water if you want to come take a look. Also comes on a Double axle trailer. Call or Txt (941)525-8155
jblocal
Senior Member Joined: September-06-2010 Location: Stuart, Florida Status: Offline Points: 203 |
Thanks(1)
Nice work! I have an 87 fish also thats getting a decent overhaul right now also. Hopefully have it in the water this weekend.
MOBCHARTERS
MountainMan, Those reduction drive transmissions are the way to go. Thats why we see them in those 28-30' boats powered with twin 350's. It's the only way to push them. I know what you mean with changing the shaft log position as there is just enough room as it is for a 1:1 gear in there... I have thought about doing that, but its more work than I want to get into at this point. I could probably move the engine foward a few inches as that would be almost easier... lol it would also have to come up higher to keep the same angle. which would not be that bad of an idea considering how low these motors sit in these boats... I swear there is only an inch between the oil pan and the bottom of the bilge... Thanks for the post tho, and I'll be interested to see how the # work out when your done..keep us posted!
Mountain Man
Senior Member Joined: May-09-2014 Location: Brevard, NC Status: Offline Points: 124 |
Thanks(1)
Interesting thread - enjoyed the posts. I'm in the middle of a total refit of an 85/86 Fish Nautique, hope to splash it around Easter. It is powered with a reman 351 (.030 over), GT-40 heads, Carb, and DUI. Drive is a new PCM 80A - 1.23:1. Replaced the shaft with a shorter ARE shaft and re-propped with a 3 blade 14X 13 w/# 3 cup. Boat has 12" Bennett tabs. We've also added an additional fuel cell (16 gal) in the floor compartment closest to the console. That will give us a little over 100 gals when full.. Note that the position of the engine and shaft log has changed from original due to the PCM reduction drive. Performance numbers and pics will be shared when done.
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 832 |
Thanks(1)
ours is equipped with trolling valve. we swing a 34" wheel so its almost necessary, that thing moves some water when its kicked into gear.
My only complaint is i personally don't care much for the fly by wire throttle controls. it takes some getting used to going from reverse to N to Forward and the other way around. there is no feedback so if your not paying attention you could easily forget and be half into the throttle by the time it kicks in. We run the thing with the trolling valve on for days on end when canyon fishing and its always worked. all it is is a controlled "slip" |
1988 Barefoot nautique-454
63 Skier
Thanks(1)
Yes, that SBC is feeling a bit flogged I would think! I've toyed with the idea, future project (and not likely, but I can dream), of putting a Peninsular 6.5 diesel in one of the larger CC's. I almost bought a running takeout engine with 2:1 transmission just to hold for the future, didn't pull the trigger. HP ratings can be mid 200's to I think a bit over 300, but torque numbers well over 400 lb.-ft. Not sure what the performance would be compared to the gas engine but economy would be great and I doubt it would care nearly as much what the load was.
Thanks(1)
Another thing on the ZF's to check out is I think you can put a trolling valve on them too. Might come in handy for you.
MOBCHARTERS
Tony, Those ZF's have quite the reputation... I'm looking at putting a 1.64/1 ZF in my new boat with the Cummins. I'm still doing some research on them tho. Skier, that WOT 4000rpm and 33mph was 1/2 full fuel tank just me on the boat. That est. of (2000lbs) is just passengers, myself, and fuel. If you add a 25 gal live well (200lbs), tools, spare parts ect. (50lbs), cooler w/ ice (100lbs), rods, reels, tackle (50lbs) and boat (3800lbs) you hit a total of (6200lbs)... That is with me and 6 people @188lbs /ea.... That is a pretty steep bill for a single 300hp 350 sbc... I can tell you this... when I get a group of 6 that could all be football players I shiver and cringe... lol but, a family group of 2-3 adults and 3 kids... omg what a difference.... 3 adults @150lbs and 3 kids around 100ea. puts me right around 1600lbs instead of the 2000! ,.... and that 400lbs is a huge difference. Unfortunately its hard to explain that to folks on the phone.. I try to be gentle but honest...
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
[QUOTE=MOBCHARTERS] Well,... It's been a long time since I've posted anything on here but I thought I'd update what I've done.
Here is a pic of the new engine we built and put in.. another view installed leaning post and livewell. Had The bottom painted. Love the lines. new 4 blade prop New Fresh Water Engine install. Marine Power 350 Vortec heads, Roller cams, bored .20 over I'm considering installing trim tabs, not sure as of yet because I plain on putting this boat up for sale in a few months.[/QUOTE WOW!!! |
Js
63 Skier
So Rick, was the WOT 33 mph at 4,000 with a full complement of people and gear? You say half tank of fuel but not sure what your load was otherwise.
One of the brochures lists a Fish at 3,800 lbs., then add your 2,000 lbs. of fuel, people, and gear and you are at almost 6,000 lbs. That's a pretty hefty load for a 300 HP small block. Not that it's not up to the task, and can do it efficiently, but I'd guess your results are pretty solid considering. A few more rpm at WOT might help. |
DayTony
ok, thanks for clearing that up. I have swapped the pumps to match engine rotation before but I always thought they could be reversed by just swapping linkage too.
The ZF gear we have in our duffy can be run in both directions. for example our cummins is std rotation and without removing the gear we can put either a LH or RH wheel on and simply run it in whatever direction we need. The trim tabs are a good selling point, especially when doing sea trial. time and money invested vs return might be hard to justify though. but what isnt on a boat? haha |
MOBCHARTERS
My 4 blade is cupped also.. i ran the boat yesterday with a half tank of fuel and at 3400 I was doing 28-29mph. At WOT I was 33mph at 4000rpm with half tank of fuel (40gal) Tabs would probably help me see the largest improvement.. Part of the reason I went to a 4 blade and went down in size was because with a full boat (6 people plus myself and a full tank of fuel 80gal) I could not reach 4000rpm with the old 14x11. I would estimate the total weight at well over 2000lbs, especially with cooler, ice and tackle....BTW Awesome vid Tony.... I have a borg Warner Valvet 1:1 and yes its easy to change the rotation of the pump, but it must match the rotation of the engine. you cannot make a RH motor spin that trans LH ect. It makes it easier to swap out transmissions as they are not RH or LH only.. I also found it hard to find RH props for an 1-1/8' shaft. This is due the the fact that a RH is considered a counter rotation motor, which means you would have a LH and a RH. There are not to many small shaft small boats out there with twin screw that run a 14x11. 11" pitch is a small amount of pitch for a twin. So finding a used RH was a bit tricky.. The new boat project will be on hold until both my other boats are sold. I keep thinking if I put tabs on my Fish it ill make me procrastinate on selling it... lol...
DayTony
that video is with an unworked acme 524
Correct but keep in mind it needs to match the rotation of the engine. |
63 Skier
Tony, good to see you have a foot throttle in the FIsh!
On the props, I think Rick said the 4 blade is new. I wonder if either Rick or Tony's 3 blades were ever re-worked, they may not be what they were when new. Hard to know what the best prop for the application is without having a few on hand to try and compare, though I wonder what Acme would recommend if they had all the details on the boat and power. |
DayTony
It is def an improvement, but. I have a sneaky suspicion that boat can perform much better than that with the fresh 300hp 350. I'm running a 13x11.5 3 blade on my fish now and pulling about 28mph @3200. Thats with the 260ish HP 351. I get about 22mph at 2800. That hull is capable of much more if propped correctly, I have heard of guys running upper 30's with similar HP as your 350 Those velvet drives are capable of running either direction if you ever wanted to run a RH wheel vs a LH. |
1980SkiNautique
Newbie Joined: August-31-2011 Location: Waupaca, WI Status: Offline Points: 20 |
Let us know if you have a build thread for the 6BT Pacemaker, as I would love to watch the project!
1980 Ski Nautique
351ci Commander |
63 Skier
That Pacemaker looks like it will be a great all weather boat. 11' beam is a lot of cockpit room!
Obviously the 4 blade was a solid improvement, the numbers tell the story. |
DayTony
what RPM are you getting at WOT?
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
I think manifold vacuum numbers with those stats, as well as WOT rpm
would help tell the full prop/motor combination story. Too bad its got to go, its been in good hands. |
River Rat to Mole |
DayTony
cool, that should be a good project.
It looks like the keel was layed up after the fact, wasn't originally offered with that big of a keel I am guessing. Whats she got for power? |
MOBCHARTERS
Tony, I think its what they call the sportfisherman..... not sure tho. It is a Pacemaker, but hard to find info on it.
DayTony
Nice, what kind of hull is that?
MOBCHARTERS
Well, I bought another project boat and will eventually need more funds to do the work to it. That is the main reason I have decided to sell her. I will always love the lines of the Fish Nautique. There are a lot of boats out there, but not a lot as pleasing to the eye.... The hard thing to compare with the 2 props that I also changed motors at the same time..... The first motor was a 1978 block sbc 350 that put out an estimated 260-270 hp. At that time I was running a 14X11 RH prop. The main problem I had at that time was when I had a heavy load the prop would slip and mpg would really suffer. I now have a updated 350 sbc with vortec heads, roller lifters, ect This engine is supposed to be puting out aprox. 300+ hp... The new prop is a 4 blade 13X13 LH as this motor is regular rotation now. So when compairing #'s you have to keep that in mind.
Here's the #' s ( full tank of fuel) empty boat Old motor 3 blade 14x11: 2800RPM 19mph 1.7mpg 3000RPM 22mph 1.9mpg 3200RPM 24mph 2.25mpg New Motor 4 blade 13X13 2800RPM 21mph 2 mpg 3000RPM 24.mph 2.2mpg 3200RPM 26.5mph 2.4mpg The thing I've noticed that I like so far with the new prop is that even with a full tank and a fairly decent load of people on the boat 4 + myself (1000lbs) the numbers don't change with the 4 blade like they did with the 3 blade. you could knock off 2 mph and .25-.5 mpg with that load running my old 3 blade. I guess One way to compare apples to apples now would be to put the ol' 3 blade back on and run it with this motor and record the #'s.... I think my current #'s would be a bit better with tabs for sure. unfortunately I think I would have to install small ones due to the exhaust placement. Since I know everyone on here likes pics I thought I post a few of my new project boat I'll be starting. It's not a CC but I was looking for something in the 26-30' range. I'm planing on putting a 315hp. 6BTA Cummins Diesel in it. Gunna cost me some $$... It's a 28' Pacemaker on paper but total length is 29'10" with an 11' beam. |
