  New Posts New Posts RSS Feed - Transmission identification
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Topic: Transmission identification
    Posted: February-07-2014 at 3:39pm
CC put those 1.23 boxes behind the direct drive Pythons (which swing 13x18 props and require a 1-1/8" shaft) and those are no problem. Joe has twisted how many 1" shafts apart with his monster 408w? Rumor has it that tranny has never had its fluid changed either. Talk about bullet proof!
Let’s not curse my transmission by saying nice things about it. It only has about 650 babied hours on it, no reason why it shouldn’t be doing well. There is a decent chance it will get its first transmission fluid change this year because it is going to be here in the spring and not in NC like the last few years.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Florida Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 11:24am
I talked To Art Cozier about it the other day. Art like me has live in a sheltered world as far as looking out side the Correct Craft World. Art had very limited experience with the Hydraulic style Paragon and had better knowledge of the Crash box Paragons(old).
As far as the PCM transmissions they are pretty robust to a degree. one of their shortcomings is keeping the retainer ring in the drum. Sad part about that is when they do spit the ring it usually tears up the housing. PCM has now replaced the old series 40 version with a new series 80. I know my new boat is electric shift other then that I will be schooling myself on the series 80 transmissions just to know what the differences are.
Thanks again for the info on the Paragon, I feel somewhat better about installing it back in the Chris Craft.
Jody
Money Talks! BS Walks! and loose change rides the bus!!!
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:54am
Yea, I haven't had one call or seen one boat in the shop with a bad 1.23:1. Seals sometimes yes but never a transmission issue outside of that.
I rode in Joes boat, that thing is brutal. That transmission made a lot of noise I have never heard from a 1.23. If it can survive that I consider it unbreakable. ha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:30am
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:08am
Joe has put one to the test with a few extra HP as well.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 9:43am
You sure don't want a PCM!
Come on now Pete... I know those PCM's are considered new-fangled technology, but if they were in any way problematic, dont you think it'd be well documented by now? CC has been using them pretty much exlusively for 25 years now! By all accounts, theyre every bit as tough as the BW's, maybe more so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2014 at 9:57pm
Originally posted by baitkiller baitkiller wrote:
if the ratio is right go for it. Those things are tough as nails.
I agree! I feel the Paragons are better than the Velvet's! You sure don't want a PCM!
Too bad Eric isn't around anymore - he worked for Paragon in his early life learning the marine transmissions.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2014 at 11:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2014 at 10:22pm
Thanks Guy's. was my suspicion it was a paragon there was not a ID tag on it, now to identify model. was bolted to a 305 Chevy in a bigger Chris Craft. I am re-powering the Chris with a 340 HP 350 Chevy. Not sure if this little gear will survive with the bigger HP and torque.
Thanks again.
Jody
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2014 at 7:47pm
Confirmed, paragon
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2014 at 5:10pm
Paragon
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2014 at 4:40pm
Any of you Transmission Savy gents Identify this transmission?
Came out of a big Chris Craft Roughly an 80 model.
Jody
