  New Posts New Posts RSS Feed - 454 Exhaust Manifolds
ssa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssa Quote  Post ReplyReply Direct Link To This Post Topic: 454 Exhaust Manifolds
    Posted: February-16-2014 at 10:43am
Also if your wondering why I'm on here with a Supra I originally started looking for a Sport Nautique.
ssa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssa Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2014 at 10:37am
I just bought it last fall its a 95 Supra Sunsport and has the PCM 7.4 HO. The gasket between the manifolds and risers were leaking going back to 2 owners before me the previous only owned the boat a year and a half. Anyway the water that was leaking down the outside was running onto the rear 2 ports and rotted the runners out before they enter the water cooled section. When I winterized it and shut the engine off after fogging it I noticed a small stream of smoke rising from the port manifold. When I got down om the floor and looked at the bottom of the manifold there was a hole that I could stick the straw on the fogging spray through. Front runners on both sides were good but both rears were eaten up from the tilt of the engine running all the water that was leaking onto them. I've looked at the manifolds on skidim and will go that route if I can't find some good used one's. But wanted to see if I could find some good used one's first with all the other money I've spent getting the boat and equipment for the summer. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2014 at 10:16am
Eric,
Tell us about what model boat the manifolds are for. It could make a difference. What's wrong with them? Failed a pressure test?
Welcome to CCfan. How about some pictures. We love them!
ssa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssa Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2014 at 3:04am
I'm needing a set of pcm 454 exhaust manifolds if anyone has a set. My risers are good just need the manifolds.
