  New Posts New Posts RSS Feed - Advice please -manifold leaking after harsh winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Topic: Advice please -manifold leaking after harsh winter
    Posted: March-01-2014 at 10:28pm
+1 on the replacement
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2014 at 11:23am
Take it off and test it. If it isn't cracked internally save money and JB weld until it leaks again then replace, Or just replace since you are selling it and the future owner won't have any issues.
Use anti seize when you install the new brass drain plugs for good measure. My boat had it's original steel plugs in it up until this last summer. They were so rusted away the threads would still grab but water began leaking by. They were never stuck once in the time I owned it using anti seize.
Someone probably over tightened the drain plugs at some point. Most people don't understand how NPT threads work.
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2014 at 12:08am
Greetings from a fellow Southwinder:
Perhaps you do indeed have internal manifold issues, but I encourage you to not overthink it:
a few years back had a visible leaking manifold crack on my 40 year old 351. Removed manifold and ground crack down to a V. Applied generous helping of JBWeld. Has held up just fine for years ever since, best 15 bucks I ever spent. I posted photos at the time, can't recall the thread name, but also have photos available on request.
1974 Southwind 18
1975 Century Mark II
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 10:00pm
1976...replace
This is the life
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 9:29pm
Originally posted by kman kman wrote:
This happened cause I haven't been able to get the damn brass plugs out to drain properly.
This will teach you to ask questions and do a site search for the problem! The issue has come up several times!
yes, I know. I just thought I was doing fine by blowing it out. Until this winter! so what would you do now? replace or try to repair?
Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 9:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 3:29pm
You could patch it but if it cracked on the outside it probably cracked on the inside too. Pressure testing is the only way to get a good look at it.
I told you you'd break its heart if you sold it!
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 2:17pm
this may be the same thing, but it's very small slow dripping leaks right in the middle of the bottom of the manifold. I'm not totally convinced it was caused by freezing. Maybe it has just rusted thru since 1976.... Anyway, one of the guys at SKIDIM mentioned the patching was possible.
Kirk
1976 Southwind 20
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 2:09pm
If it is cracked, it needs to be replaced.
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2014 at 1:51pm
Well, I think I jinxed myself by taking about possibly selling my boat last week. Went to start her up last weekend and the starboard manifold has a couple small water leaks. I have heard some minor leaks can be patched with JB Weld or something. Any advice on how to make sure the leak is not getting into engine??   And how can I tell if it is repairable vs needing replacement?
This happened cause I haven't been able to get the damn brass plugs out to drain properly. I've been fine for 4 years but we have had 50 sub freezing days this winter and mother nature won…
Kirk
1976 Southwind 20
