  New Posts New Posts RSS Feed - Desulfator
Desulfator
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: Desulfator
    Posted: April-04-2006 at 1:13pm
Darrel:
Home Depot sells a Husky brand battery charger for $60 that is electronically controlled and has a desulfating mode along with many others. A great deal on a battery charger. I have heard the desulfating cycle works well.
Husky battery charger
81nautique View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2006 at 11:02pm
Darrel,
I've never used one on my boat but they are quite common in motorhomes. Most good quality motorhome converter/chargers have a desufalte cycle built in. From my understanding it is a bigger problem when the battery is drawn down below 80% on a repeated basis so if you are one to use your stereo for a few hours at atime without running the engine it could help prolong battery life.
It's a bigger problem on deep cycle batteries when people run them dead and then recharge em fast. We do a lot of boondocking with the motorhome and run off of my battery bank for long periods of time but I always make sure to start the generator and recharge the batteries before they get below 50%.
Darrel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrel Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2006 at 10:38pm
Anyone use or try a battery desulfator to prolong battery life?
