  New Posts New Posts RSS Feed - Changed Tranny Fluid in 1995 1.23:1
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Topic: Changed Tranny Fluid in 1995 1.23:1
    Posted: March-24-2014 at 3:41pm
I do believe this is the hole you need the tube to be in. Just changed my trans fluid yesterday. Figured I'd get a pic of the hose in the dip stick hole.
Got out almost 2 quarts exactly.
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2014 at 2:01am
levinmark, Now that I finally have activated my profile picture I can say how much I like the colors on your boat, great color combo in my biased opinion.
I really wish I had put my pen light into the fill hole to see what I was fighting, the copper tube trick could have saved a lot of time.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 11:55pm
I used copper because it was in the junk box leftover from the icemaker install, no other reason
Gary- Had 3 Volvos in a row, it wasn't the Chinese, but instead their prices that got me to buy a Ford.
levinmark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levinmark Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 7:53pm
Im sure you can use whatever type of tubing you want, as long as it is rigid enought to not bend easily and fits down the little hole. Only reason I went with copper is from reading other posts on the process.
levin
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 7:38pm
Ok I have an (obvious?) question.. why copper?
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 4:06pm
I hear you on the Chinese stuff but sometimes you have no choice. As Volvo owners the Mrs always wanted another until the Chinese bought it from Ford. They aren't even on the list anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 3:30pm
Gary, I should have thanked you for taking the time to post the picture of the Mitivac, it does look like a handy tool. I was just making the point that the pump was not the issue, it was the lack of knowledge about the copper tube trick on my part.
BTW: some of that Old Tech says Made in USA and works really well compared to modern Made in China products.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 2:29pm
Just trying to help out thru experience. If old technology like drill pumps, horse and buggies and rotary phones work for you then by all means use what your used to
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 1:26pm
I did not find the Copper tube note in the posts I read, that would have worked out great. My Malibu skier that we sold last year had the 350 chevy mounted so low to the hull that you could not pull the oil drain plug. I always changed the oil with my drill pump and it performed quite well so my pump was not the issue. My plastic tube sure was. I put it in many many times trying to find the oil with no luck. I did not think of trying a copper tube. Great idea. I will save that for next time. My 1.23:1 did not have room for a turkey baster, my fill hole is too small.
If the Exhaust did not sit right above the Tranny it sure would be easier to work on it. Thanks for the tips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 10:23am
Mark do yourself a favor and retire that drill pump and get something like a mity vac vacuum pump. Then like Mark says put a copper extension on. You won't believe how many different uses you will find for these pumps
Post Options Post Options   Thanks (0) Thanks(0)   Quote levinmark Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 9:16am
The reason you were only getting 1/2 quart of fluid is beause you didnt have the tube all the way down to the bottom of the tranny. If you pull the fill plug and look down there with a flashlight, you will see a little hole about that is a little larger than 1/4" wide. This is where you need to fish the suction tube down to get to the fluid. I use a 1/4" copper tube to do this. Plastic tubes may curl forward and up into the tranny when you think you have it in the hole and then it might get stuck and break off. Might be a little easier than pulling plug at bottom.
levin
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2014 at 5:28am
I changed the Trans fluid in my 95 Ski Nautique with the 1.23:1 trans.
On my Engine cover the decal listed the Tranny fluid as Dextron 3. The fluid in the tranny was red so I agree with the decal and used Castrol Dextron/Mercon, This Castrol meets the latest specs for all makes Domestic and import tranny fluid.
Draining the tranny is a chore. After reading many posts here about sucking it out I went at it. After dinking around for an hour and only getting 1/2 quart out using a good drill powered suction tube I gave up.
My tool can drain the engine oil in about 5 minutes but I could not find a route to get the tube in the proper place to drain this tranny.
I even raised and lowered the front of the boat trying to put the fluid in a sweet spot where I could drain it but no luck.
I decided to pull the drain plug in the bottom of the tranny. I cut down a gallon Dryers round ice cream container to about 2 1/2 inch height and it worked great to catch the oil drain, a cut down milk jug may have been enough. Only spilled a couple drops and it drained in about 10 minutes till it stopped dripping.
The trick to removing the drain plug, it is an allen head plug, is to heat it first. Even with a 12 inch extension mine would not budge while cold. I decided the factory had used a sealer that was now old and hardened and locking the plug. I used my small Propane powered torch and warmed the area around the plug. Once it was hot to the touch, not enough to burn me but a little uncomfortable to touch I put the Allen wrench back on it, I did use an extension to get more leverage and it spun right out. I used maybe 50% of the force I had previously used when it was cold and it came right out while hot.
Never moved cold, I think I would have stripped the plug or broke the allen wrench if I tried any harder to pull the plug cold. When I put it back in I used an engine thread sealer. Same stuff I would use on head bolts or water pump bolts that go into coolant. The stuff works as a sealer and as a low grade thread lock. Put 2 quarts new fluid in and was done in no time. ( before I put the plug back in and after the tranny had drained I put a half quart of new tranny fluid in and drained it into the bucket, I did this to let the new clean fluid flush out a little more of old sludge that may have been sitting on the tranny bottom.
If I had known to warm the plug first and skipped the suction technique completely this could have been done in less than one hour. I ran it two and a half hours Monday evening, ( nice to have daylight savings time back )after this job and not even a drop spilled.
Make sure you use a thread sealer on the plug install. I removed the Engine cover( two pins and the struts) rear seat, and rear Center floor section for the room I needed to access the drain plug and install and remove the bucket I made.
The rear seat and floor are only held by the two large hand screws so removal is fast. The drain is on the drivers side of center on the bottom of the tranny close to the bell housing. One Boo Boo, I failed to check the fluid level while floating on the lake. I will have to do that next time out. I know best case it to repeat this procedure to include the tranny cooler and tubes but that will wait for season end this year. I think If I do this each year or at 100 hours that is good enough for me. I hope this helps someone do this job a little quicker than me.
